Perusing through today's "Doctrine Dispener" offering, a curiosity struck me about the "Wash n Wear" feature on Maytag washers in the 1960s.
In looking at the literature for the A906 there is a button labeled "Wash n Wear". The technical specifications on the last page list that cycle as having a "cool-down", "spray" and "deep power" rinses. All other wash cycles have only the "spray" and "deep power" rinses. When you go down to the model A806 there is a "Wash n Wear" selection button but all it does is select high speed agitation and low speed spins. A seperate "Permanent Press" cycle on the A806 would not be introduced until February of 1969.
Correct me if I am wrong, but from service literature I have seen it would appear that the timer and other related control circuitry of the A906 when it was introduced was exactly the same as that which was used on the 160, A900 & A902. The only difference being that the A906 now had the 19 gallon tub with its attendant power fin agitator and faster agitate speed.
Maytag was notoriously conservative with the addition of "new-fangled" features such as "Wash n Wear." If I recall correctly, Kenmore introduced the "cool down" feature in 1958. I'm not sure when other manufacturers introduced it.
This means that Maytag first introduced this feature earlier than I had first thought. I am not certain what year the 160 push button machine was introduced but I think it was in the 1958 or 1959 range.
It then took them 10 years to introduced this cool down feature on any other machine!
Here's the original Wash n Wear timer sequence that was used from the introduction of the 160, through the A900, A902 and original A906. The A906 control was simplified in August 1968.
