My dishwasher has 2 problems.
1. The initial drain cycle does not end. The water does drain, though there's 1/2inch that's left in the bottom of the sump.
2. The door sensor in the door is not registering. I pulled out the microswitch and cleaned the contacts, also where the wire plugs into the control board. Still no joy. If I use a multimeter I can see the continuity between the 3 pins on the microswitch change when it switches, and resistance is low when on (0.5ohm).
I can't find any service manual - anyone know next steps?
