So here's me doing a bit of washing on Sunday with the Miele W1075. Wasn't paying total attention but suddenly it dawned upon one that wash cycle was taking rather long time to finish.
Finally washer did get round to draining wash water, filled for first rinse, then sat sitting there. Noticed while could hear the normal clicks, wasn't hearing the purring of mechanical timer's gears.... This is not good...
Turns out washer's timer seems to be kaput! It will click off increments, but won't advance. Well not all the time and on time anyway. When moved to certain points in drain or spin timer will click over to next bit, but that's all.
Will give a call to Miele USA on Monday to see what there is; highly doubt timer motor (or worse) electronic control are still available for this machine. More to the point if they are and cost quite dear will have to make a decision...
Much as one loves "Big Bertha" she is getting on, and if this latest incident is going to run three or more hundred in parts and labor will have to consider options.
Washer long has needed a hot water inlet solenoid (NLA from Miele USA), and don't think cold water triple inlet is available either.
