My General Electric Refrigerator/Bottom Mount Freezer. P1
Louis,
What age of refrigerator do you think would be comparable? I have a service manual for a '61, and I can check behind my '65 to see if there is a schematic.
Jeannine
Hi Jennine. I would imagine the 1965 is the closest to mine if you have it. I now believe mine is a 1968 model. Judging from the amount of bare/broken wiring I found, I'd say this refrigerator has been out of service for many years, which may explain why it's so pristine. So far, every time I put in my model number I have gotten nothing.
Hi Louis, Unfortunately, I have not had much luck. Neither of the Americanas have a wiring diagram on the back, nor did the 1965. I did attach pictures from the 1961 manual for model number TC-469V which is top fridge with swing out shelves and bottom freezer, although it may be too old to be similar. These are just the diagrams, there are a few other pages about electrical parts that I can scan for you. I've also attached pictures of the compressor from one of the Americanas, and also of the 1965 Coppertone when we had the back off to blow out the dust before installing it in the house. Not sure if any of this is helpful.
Wiring Diagrams For GE FG Hot Gas Defrost Ref
Thanks Jeannine, Your 61 diagram is the one needed except the compressor is the older one that has four terminals instead of three like Louie's, so the wiring between the older style relay and condenser fan motor are different, but that does not matter as Louie is using the newer 3 in 1 relay.
John
Some detailed pictures:
<script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Maybe onto something....
Louis, it seems that the wiring diagrams are very similar for the defrost and compressor control on most of these. Please see this drawing.
It seems the brown wire is supposed to be the Line side of the power cord, only. It needs to go to the power cord but not be tied together with anything else.
The white (ivory) wire was part of the original 3-wire condenser fan circuit which you will not use. Isolate it.
Remove all the connections in the compressor compartment except the single wire to the defrost coil.
Connect the power cord line side to the Brown wire.
From the Orange wire coming out of the cabinet, connect the following things together:
-Orange wire from cabinet
-One of the Supco power input wires.
-One of the fan motor wires.
-Power cord Neutral side.
From the Black wire coming out of the cabinet, connect the following things together:
-Black wire coming out of the cabinet.
-Remaining Supco power input wire.
-Remaining fan motor wire.
-Remaining Defrost coil wire.
Yes, I probably meant to type "live" there. Got a few things going on at same time and typing too fast.
If you have a 3-wire grounded cord, it is the black wire. If it's a two-wire polarized cord, it's the smooth wire, going to the "smaller" pin on the plug.
The Neutral is the White wire on a 3-wire cord; or for a 2-wire cord, the grooved wire, going to the larger pin on the plug.
It won't really matter much on this one because the original cord was non-polarized.
One thing I noticed....
... in the pictures you posted; did you remove the insulation from the lower part of the fridge under the rear cover? If that was missing to start with, you need to replace it with more fiberglass padding. If that space is open without insulation there will be a good chance for frost or moisture buildup in there; plus a bad loss of efficiency.
It's working beautifully. Refrigerator temperature is 37F @ #5 on the thermostat. Freezer ice trays have all set and it's cycling correctly. Did I mention it's whisper quiet?
David, I can't thank you enough. Your expertise saved yet another vintage refrigerator. Man, you're on a roll!
I also want to thank wholeheartedly John (Combo52), for all his advice and help.
A big thank you to Jeannine for the schematics.  And thanks everyone for their advice and encouragement.  Next stop, COSTCO!
BTW, David, yes, I had removed a large, one piece fiberglass mat from the back of the refrigerator in order to see where the wiring was going. It was far easier to remove than to put back! I'll post a few more pictures of the compressor compartment before I button it up.
Glad it's working correctly for you!
The real test will be after a few weeks to see that it's defrosting correctly as well. I believe you have it connected right so that if the defrost control is good, it will work.
John L also got me interested in these fridges, to a degree where I notice threads with folks asking for help with them. Without his info on the defrost control, I would probably not have got John G's fridge fixed; and therefore would not have had the experience to assist you remotely.
Yay, Another GE Frost Guard Refrigerator Saved
Yay Louie and David, you got it going, A big Thank You to David who has more patience than I do, It is often harder for me to explain something to some one else. I knew once you got the compressor to run with the 3-in-1 relay that this ref would be OK, by this time period these GE refs were pretty bulletproof.
As David suggested put all insulation back and be sure the black metal rear cover is sealed perfectly to the cabinet, even tiny air leaks will cause problems in time with frost and moisture in the insulation. Probably fresh new soft Permagum is the best choice.
John L.
Louis,
So glad that it appears to be up and running as it should be. Fingers crossed that it will go on to live a long life.
This has also reaffirmed for me that I need to get at least a couple of my guys up to David, or convince him that he needs an all expenses paid trip to Florida for a few days--lol.
Final reassembly of rear panels.
Yes, that is a trash bag. Because the rear panel was not sealed properly, the fiberglass insulation was damp. After drying it out, as a extra measure, I added the plastic to protect the insulation. As John suggested, I applied Permagum to seal the rear panel tightly againt the refrigerator back.
Supco 3 and 1 starter relay in it's permanent location, wiring tidied up.
All buttoned up.
Freezer is registering 40F. Ice is melting. It was fine this morning. I hear it clicking, as like starting then stopping. The refrigerator section seems to be OK. Defrost timer? Low refrigerant? Dying compressor? Don't quit on me now Spacemaker.
I spoke with David, seems like I got the relay in a starting loop by not waiting 5 minutes to plug in the refrigerator again. I'm unplugging it now and will wait 10 minutes in order for it to reset. If that doesn't work, I'll need to reorder another 3'n1.
Frustrating!
These 3-in-1 devices and other Supco start devices are supposed to be equipped with a specially calibrated overload breaker. It is designed to have a long reset time. If the overload trips, it should stay off for at least 5 minutes. This is to allow for the start device to reset; and for pressure to equalize in the compressor. If it tries to restart too soon, it will not be able to start. Louis's overload was cycling off and on every few seconds and not allowing any time to reset.
