My new 1963 Whirlpool Imperial Mark XII set
Took the pump off of my ‘63 RCA Whirlpool Imperial Mark XII washer (in the process of a refurbishment process) and the pump is much newer than I thought it would be. Looks like it could have possibly had the belt and pump replaced sometime in 1998 since there is a date of 2/3/98 on the drain pump
That is something I might consider but I am leaving it the way I found it. Don’t want to try to hot rod it and something ends up breaking. I will be ordering a new belt so that should help the washing performance a little.
63 WP Washer Tear Down
Hi Sean, it does not look too bad, you should not need new bearings, maybe a new spin tube, although if you use double top seals on both the agitator shaft and spin tube you should be OK, what does the top of the agitator shaft look like ?
If you clean it up and you will get lots of use and many years out of this washer.
Hi John, I got a picture of the agitator shaft and this is the older style since it doesn’t have the splines in it like the later Whirlpool belt drive washers use. Maybe I’ll need a spin tube but I’ll have to look into it once I get the basket drive off tomorrow.
Did Whirlpool use the same upper seals on the direct drive washers? I believe you mentioned that Whirlpool used the same seals and bearings on the direct drive washers but I am just double checking just to be sure.
WP Built DD & BD Washers
Used the same inner and outer diameter seals for the spin tube and the agitator shaft, there were several different styles used over the 70 years these two machines were in production but they are completely interchangeable.
Reply #68
All it does is move the belt to the other side of the pulley reducing the air output. I’ve manually switched the belt to the other side of the pulley and it does reduce the air output and certainly makes the dryer a bit quieter but it doesn’t work since a part of the belt shifter is busted off and doesn’t do anything at all. One of these days I’ll look into a replacement belt shifter but it still works by reducing the heat output but not the blower/fan air output.
Got the outer tub out, and this is what the baseplate looks like after a quick wipe down. Seems to be in good shape and there is some rust on the left front of the base plate but that’s more than likely from someone overfilling the bleach dispenser since the bleach and fabric softener dispensers are right above that area of the baseplate. Plan on putting POR15 on that area of the baseplate and the rest of the inside of the cabinet to prevent it from developing any rust in the future.
2-speed
So does this dryer have 2 tumbling speeds? I thought moving the belt made the drum tumble slower & faster, depending which pulley the belt was on?
Reply #78
Not 2 speed tumbling but a 2 speed air output. With a lower air output, items tend to not get pulled towards the exhaust outlet as easily and is ideal for delicate fabrics. Will also make the dryer more quiet since the exhaust fan/blower is running a lower speed as opposed to the high speed.
Reply #80
Yes, the gentle speed has the 4500 watt output and the normal speed has the 5600 watt output. The high heat temperature will still work on the gentle speed but will take longer to reach 160F as opposed to the normal speed drying temperature. I will experiment to see how well the gentle speed dries things such as sheets compared to the normal speed drying temperature.
FSP Whirlpool part, that has been obsolete for quite awhile now. I would suggest checking on eBay from time to time, or simply make one yourself. As long as the tube seals against the tub, and is the same approximate height and diameter, it should work.
Another update
There was a good used transmission on eBay that was too cheap to pass up since it was only $44.00. Only things I had to do was add oil and transfer the original wig wag and cam bars on to the newer transmission since the cam bars that were on the transmission were bent which more than likely was from shipping. Not sure what the new-err transmission is from but more than likely from the early to mid 80’s.
