My newest acquisitions...
Phil-
I don't think the tub is original. That shade of blue wasn't used until the rollermatic's were introduced. Have you checked to see if it still has the original transmission?
Here is a picture of Jetcone's from way back. I'm not sure if he still has this machine but it is a good example of what the US made version looked like.
Patrick
Not original tub and pulsator
Look at it this way, it may not be original stock, but the replacements kept the old girl going and her shell wasn't thrown out to the landfill. And as rare as the Control Tower models are, this one got a new lease on life.
Yes!
I totally agree with Bob. The outside of the machines are what really catch the eye and they are in great shape.
You may be able to scare up the correct agitator someday but the tub is larger (12 lb. vs 10 lb.) so you actually have more washing capacity. I have also found the porcelain to be better on the rollermatics in my experience.
Anyway, look forward to hearing more about the mechanicals!
Patrick
It does have it's Unimatic transmission as well as the original fill valves and the tub is different from Rollermatic tubs (look a the shape of the ring which is flat). I think that early Multimatics with 9 lbs tubs had tubs similar to this one.
I think the color of the porcelain coating in the original tub should have matched with the dryer drum's color.
You could be right about some of the early Multimatics having this tub.
I cant tell without seeing in person but your tub looks a lot like the tub from my '68 rollermatic. Here's a picture of it out of the machine.
Here is a picture of the tub in my '63 Multimatic. You can see a ridge in the middle of the rim around the top of the tub.
Just thought I'd throw these up for comparison.
Patrick
I haven't defeated the lid switch so here's a video of the timer... It ain't that noisy in reality, it's just that the microphone in my phone camera seems a bit too sensitive...
<iframe width="420" height="315" src="" frameborder="0" allowfullscreen></iframe>
Patrick, yes I had it set on small load (and I did pause the video at some point to make it shorter).
I have a '68 Rollermatic just like yours (a WN7 Gold Crown model) and the tub also has the ridge at the middle of the rim, just like in the later 12 pound Multimatic tubs. It's hard to see on your picture probably because of the angle.
See my Rollermatic tub, I think yours should be the same.
agitator chart
Here is a nice reference to see what should be in your machine as far as an agitator.
I guess Jetcone decided to go for the '58 agitator in his. If only these were still available.
Beautiful find Phil
And a real neat designation on the WIC-57 there! That makes them extra special! The '57 was an odd year and as the cabinet was lowered so the tub was cut low for that year. I don't know if they carried that tub over in later years or not, Robert knows better about this than I do. But you could very well have a factory 1957 tub with Canadian porcelain, or it could have been a replacement tub manufactured in the 60's and installed but it would have to be for that particular machine as the tub would hit the cabinet if it wasn't.
Odd though that the jetcone agitator is hitting the lid! Sometimes they put rubber spacers under the cones and maybe yours was not installed correctly?
Nice vanilla color~~ we should get ours together for a wash in!
Yes Patrick I still have my white '57, it came off the Farm in Aberdeen, Robert found it for me and I am keeping it for good. Just rebuilt the timer in it.
Yes John I AM hoarding that charcoal set!!------KERRRSLAPPP!
OMG - congrats!!
The U.S. porcelain was more gray in 57 but Jon's right, this could have been a Canadian made version of the machine so it may have been a different color. You have the machine, that's the important part, the rest will come.
I'm glad it's working, that's a huge bonus! Congratulations on a great set and rare piece of history.
Jon,
I removed the agitator, removed the water bellow to see if there was anything like rubber spacers and there were none, there was not even a large lower cone support washer... And the agitator goes close to the bottom of the tub so I can't see how it could go any lower... I look under the cabinet and at the tub support, everything looks ok there too.
I guess I found what's the problem:
Greg, the porcelain inside my dryer (which is also a Canadian model - DIC-57) is gray too and that's what I expected to see in the washer. Frigidaire often used different porcelain colors on Canadian models (usually black instead of gray or blue)... The picture of Robert's WI-57 shows a blueish tub too.
Another video of the washer spinning. I had it a bit overloaded with towels but I was surprised to see the good rollover, even with the jet cone agitator.
<object width="420" height="315">
<param name="movie" value="http://www.youtube-nocookie.com/v/DD7WWR0Wf5o?version=3&hl=en_US" />
<param name="allowFullScreen" value="true" />
<param name="allowscriptaccess" value="always" /><embed type="application/x-shockwave-flash" width="420" height="315" src="http://www.youtube-nocookie.com/v/DD7WWR0Wf5o?version=3&hl=en_US" allowscriptaccess="always" allowfullscreen="true"></embed>
</object>
Interesting thread
Another difference. Phil, you said yours has the alternating hot/cold valve for warm. Ours had the mixing valve. We only had that, the alternator, on the Pulsamatics.
Really?
Here's a shot of the valve... I have recently seen very odd stuff that came from the Canadian Frigidaire factory. They quit making Rollermatic washers and matching dryers in 1970 here and they still used some parts from the mid-sixties models but with updated looks of the "N" line washers.
Its important not to compare the colors because the Canadian versions of the machines had different wash tub colors. While this tub could have been replaced, the tub in this '57 is clearly the correct version, just in a slightly different color.
Here is what I was looking for - Robert's '57 tub and agitator. Geez, talk about factory fresh. It actually has a supple look to it! It actually has a supple look to it!
That's cause I found a brand new set of gray rings for the '56 and '57 models about 15 years ago, along with a brand new cap, pulsator and detergent column. They are still totally supple today.
Show us the Insides of your Frigidaire, check out the color of Eddy's rollermatic tub in post 151757...
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?7839
Again - congrats Phil on such a fantastic find! Who would have thought these would have been kept together all of these years.
To add to the tub color discussion - I also agree that the tub is more than likely original to the machine. However, published in the April 1957 Tech Talk, there is a bulletin discussing the change from the US grey tub to the blue tub - so in theory either tub color is correct for a state-side '57.
Ben[this post was last edited: 6/9/2012-16:30]
Fantastic information Ben! And I also just saw your email.
Can you tell me what kind of valves I have on my washer and if they're the original ones?
And they were kept by the same owner but not together. The Filtrator dryer was now matched to a Frigidaire Gallery front loader and the washer was in storage.
Excure the confusion. Thanks!
My Gram's 55 Pulsamatic achieved warm water by alternating hot and cold. It was hardly a thermostatic valve. Our Tower Unimatic made warm water by mixing hot and cold at the same time. I should say that ours was a Custom Deluxe. Your Custom Imperial has a thermostat to control precise water temperature. Have I got it right? How cool! There was a time when you got what you paid for and your money's worth. The Frigidaire Custom Imperial in 1957 was just such a time.
The newest version of Kitchen Aid which wears a Maytag badge has this same thermostatic hot/cold, hot/ cold flow. My mom has one and it reminds me of my Gram's Pulsamatic, so much fun to hear it and so soothing. I could sit and listen for hours--a waterfall lullaby.
[this post was last edited: 6/9/2012-18:09]
57 Frigidaire Washers
My WI 57 washer does have a gray tub that matches the dryer, the washer also has the more conventional thermostatic inlet valve. But you are absolutely correct Michael Frigidaire did use the cycling thermostatic inlet valves here on Pulsamatic models, these cycling valves were an early electromechanical version of the electronic thermostatic cycling valves that were reintroduced on KM DD washers in the late 1980s.
