Hi Gang,
I ran this KDP-18 today, as I'm finally unpacking my dishware. It ran perfectly fine. A little while later, I started another load. Some where in the wash cycle, close to opening the 2nd dispenser it Tripped the GFI. I reset the GFI and started the Wash cycle again. It ran about 10-15 Seconds, then tripped the GFI again. I looked inside and there was standing water. I reset the GFI, but this time I pushed the "Cancel Drain", button. DEAD Short - GFI Instantaneously tripped. Am I correct in Thinking the Drain Solenoid is Bad? Am I on the right track.
If so, Does anyone know the Part # for a new one? I'm also thinking I should get Fill Solenoid, as well, to keep as a spare. Anyone know that part #,as well.
Also, should I consider keeping spare timers, or pump/motor parts in stock. Thank you everyone,
Any help would be Greatly Appreciated.
Best Always,
Louis
Best Always,
Louis
