Never Used Early Eighties Whirlpool Dryer
Reply# 4 That is really why I posted the ad due to the story. I wonder what happened to the matching washer that supposedly was being installed when the FBI burst in.
Thanks for the pictures and additional information Glenn.
Melvin,
I noted the installation instructions for the washer and figured it got installed before the feds broke down the door.
That's some terrible lighting - makes the Toast look very anemic.
lawrence
Even if there was a unused washer paired up with this dryer, it still wouldn’t really be worth $900. Probably would be in the same shape as the dryer since it looks like it was stored in a somewhat damp environment all of it’s life, but would need to be gone through since the belt would probably have flat spots on it and the pump would probably be locked up after sitting for nearly 40 years.
Reply #10
Not sure, I believe it may have been a auto dry of some kind. Permanent press for sure is timed drying with a cool down.
The Ex Heavy, Heavy, Med, Light cycle range is standard timed operation, no auto-dry on this model.  The labels are for convenience of the user to match-up a selection based on the (perceived) composition of the load instead of mentally calculating a time ... and so marketing can claim it's a 5-cycle machine.  The timer gearing is the same all the way around so, short of a wiring diagram with timer schematic, the effective time can be measured by comparing the arc-distance to the time markings in PP.  The "Regular" cycle has a 5-min cool down vs. PP having 10 mins.
Reply #13
Looks like it’s 90 minutes or possibly 100 minutes of drying time. Most dryers (at least ones with a mechanical timer) are required to have a auto dry cycle and I believe it was mandated by the DOE or something or they just put a auto dry cycle and have a cycle or two with different temperature options to allow for some flexibility despite there not being a separate temperature selection switch.
I tend to like dryers with a auto dry where it advances the timer when the heating element or burner cycles off and pauses the timer once the heat kicks back on. Moisture sensors tend to be finicky, sometimes they work really well or leave the clothes damp, sometimes fail all together leaving a load of wet clothes. A auto dry timer may be slightly less accurate than a moisture sensor but will always get things dried regardless.
Reply #15
Not sure, I’d say about 2011 or 2012. It could have been a mandate or appliance manufacturers decided to put a auto dry with a medium to low heat and timed drying with high heat to allow for more flexibility without adding a temperature selector switch. Sometimes it’s just cheaper to build everything into 1 timer since the appliance manufacturers’ business plan is to make money along with filling in customer demand.
I want to say it was earlier then 2011, I don't recall any timed dry only being offered then but I could be wrong.
IMO the best dryer is one that offers over 90 minutes of timed dry and has a separate temperature knob offering fluff/low/med/high. None of that wrinkle guard stuff which now takes the place of the normal timed dry cycle.
Hamper door and drum light.
Its painful how simple things have gone by the wayside, but sadly everything is about compelling customers to buy complexity and extra features. Holding off on preferred options until the higher end models. Ect.
Reply #17
Whoops, 22 years off. I thought it was mandated sometime around 2011 or 2012 since there were still quite a few dryers that were sold new with only timed drying cycles in the 90’s and 2000’s.
What? A LIfe Sentence !
For "acquiring" a washer dryer pair?
Maybe the washer was held by the FBI as evidence.
Maybe it was a money laundering operation.
So many questions.
