My laundry is just 20A 230V radial on a dedicated RCBO (combined breaker and GFCI) as per the current regs here.
The T1 draws typically about 700W in use although it's rated maximum 1.1kW
The W1 in the version here can draw up to 2.4kW during heating, so I assume the US version will just have a smaller and thus slower heater.
With any appliances rated for use with a 15 amp plug and socket there's an assumption that the socket can provide the rated power. If it can't, you really need to rewire.
If the two machines cab plug into a single dryer outlet using an adaptor they would make sense but, if you've only 15 amps possible on a single outlet there's no way you can run a washer and a dryer off it!
Also hot fill won't really help that much unless the tank is located right next to the washer as it will fill before it's drawn any hot water. That's been the main reason lower water consumption washers in Europe don't bother with hot fill anymore. All older machines here hooked to hot and cold.
