New Persil and older Miele washers
luxflairguy
Mar 9, 2006
1,462
Wilmington NC
I'm off to get a bottle of the new Persil detergent today and wonder how much should I use in my Miele W1930.  I'm not sure the dosage on the bottle will be correct for my smaller machine.  Any suggestions?
Thanks!  Greg
A suggestion
Since that Miele (if memory serves) doesn't have the "Waschlauge seal" which later models had, a fair amount of the detergent is going to run into the draining system. I'd use the standard dose first and only then adjust down if there's a problem.
Which, there won't be. You're working with two of the best products ever to come into the laundry room.
I use Persil powder or Persil Pods/Pacs in my W1930 and have no sudsing problems. I use the smaller scoop which came with my Sears powdered detergent. It measures 50 CC per level scoop, to which I add a level TSP of STPP if I'm doing whites.
Thanks guys!  I bought a bottle of the intense fresh powder--hate the scent it's going back!   But did one load of whites using the recommended dose and I'm more than impressed!  But the scent!!!
I've always used universal powder and has me wondering if the 2 Tbls coffee scoop I've always used isn't enough.  Thanks again!  Greg
@Keven
If you use powder in an older Miele, it doesn't get flushed into the draining system when you use the detergent dispenser. Older Mieles always start filling through the prewash compartment for the main wash. After a while the water starts flowing through the main wash compartment. My mother's 1975 W423 had that system and my 1991 W715 has it too.
Panthera
I'm wondering how you like the US Persil vs the German. You have a unique position of having been able to use Persil a lot in Germany, possibly German Persil here, and US Persil.
Scent is why I've so far not gotten around to trying Persil. I've heard it's pretty potent, and I've come to dislike scents in laundry products. A gentle scent, fine, but it seems like the scent level of today is so strong that the scent will warp the finish on the inside of the dryer door...
I'm currently using Wisk (conventional top load type). It was cheap, and I was curious. So far, my big complaint is that the scent can be strong and lingering, although I'm getting better that controlling the problem. (Careful dosing. Also second rinses with some loads may help.)
In non-SLC Miele washing machines...
we service people tell our customers to use no more than 1 heaping teaspoon of powder. For HE liquids, pour until it reaches the diameter of a US quarter and stop. Never pods. Half-again for the large capacity machines like the W4802. I've seen more damage from over-soaping on both washers and dishwashers!
@foraloysius- many Mieles have a "feel good" fill. The first +/- 5 seconds of fill runs down the glass with the interior light on so the user can see the water and feel good that it's filling. Then, the rest is diverted to the regular fill path with the light off.
Chuck
'Older Mieles always start filling through the prewash compartment.."
My W1070 does none of it; for main wash water goes down the right side (main wash) of detergent drawer.
However IIRC all Miele washing machines going back to the 1980's (if not before) use the ball/valve system to keep detergent from being flushed down sump when filling.
I'm pretty sure its the late 80's early 90's when the eco valve came into existence on the Miele's. All of the Brown control paneled Miele's I've had dont have the valve and fill first through the prewash compartment to fill the sump.
My W423 from the mid 70's like Louis's fills first from the Prewash side and then the timer clicks and it starts filling from the main wash compartment. The early electronic control models from the same period I've used do exactly the same thing.
My understanding with the Feel good fill on the later ones, is that that is whats priming the eco valve. The water runs down the glass, through the boot into the outer tub, just enough to prime the valve and then switches to the dispenser to ensure that no detergent is lost to the sump.
Thats why with liquids you need to start immediately or you need the liquid insert for the tray, otherwise given enough time it'll run all the way through into the sump.
Is the "eco valve" you're talking about the concertina hose at the bottom of the suds container that has the ball in it that floats inside the hose and blocks the draining of said container? Forgive the difference in terminology... I'm still learning something new every day!
Chuck
The Little Giants fill as Louis states. After a quick drain, then a brief flow of water down the door as the light turns off, when that shuts off, there's a 10 second or so flow through the prewash compartment and finally the main wash flush. I also assumed this was to prime the ecovalve.
Hi Chuck,
Thats right. As the sump fills with water, the ball floats upwards which semi seals the sump from the tub and stops the detergent washing into the sump.
When it starts to drain and the sump empties, the ball drops down and the water flows past it. Its night a tight seal, it just has to be enough to stop the detergent ending up in the pump before the wash starts.
Cheers
Nathan
Gee, I'm also getting a lesson on how my Miele dispenses detergent!  I've had a W1918 and dryer and the current W1930 and dryer.  I do miss having the higher temps of the 1918.
But back to detergent!  Your Lordship, I did one load with the new Persil with the bad scent.   The results were superior to my past with Persil universal powder, using 2 T per load.  The load I ran yesterday had 3 nasty kitchen towels from cleaning my range hood.  Lots of old thick grease was on the towels.  Yes, one did have a commercial degreaser on it, the others did not.  With the universal powder the grease would leave stains, this did not.  I thought everything was whiter and really liked that I didn't have to do an Oxi-clean soak.
The bad scent bottle goes back tomorrow and yes, Freddie's carries the original scent.   Is it tomorrow yet?  Laundry is piling up!  G
I was under the impression at WallyW had ALL the different "mixes."  Wrong.  So I opened the lid of the "intense Fresh" sniffed and said that's not too bad.   I brought it home.  WRONG!!!!  I line dry in the house and my eyes watered and I coughed and coughed.  I finally put the rack in the garage.   Stuff smells great today.  But it isn't the scent I've had for years.   So off tomorrow for "original scent."
BUT!  You've not chimed in on dosage.  Have I at 2 TBLS of original powder been under-dosing?  I did the same with Mega-pearls.  I'd like your take on this...  G
Eco Valve
Actually the suds container is always thightly sealed unless the pump is running or after cleaning the coin trap when there`s no water in the system.
I think that short pre fill over the door boot and glass has nothing to do with preventing detergent loss, but might keep the boot clean and prevent from squeaking sounds of dry clothes rubbing against dry glass at the commence of a cycle when loaded at full capacity.
On the other hand older Mieles without the valve indeed relied on a partial fill over the prewash compartment to keep detergent loss at check. My mother`s 1970`s Miele even recommended to add the detergent for the prewash while the washer is filling.
However if the Eco Valve ever failed (no more thight seal) you`d notice very wet clothes at the end of a wash cycle because quite a lot of water is backing up into the suds container.
As to dosing of Persil I`d stick to manufacturer`s recommendations and see where it gets you considering that a regular sized load in the US means only 6 pounds of dry weight.
As to the overpowering scent you wouldn`t believe how fast we adapt. Brought some Tide Original Pods from the States, not being used to a similar scent I found them unbearably strong when I used them for the first time and didn`t like them at all. After a week I hardly noticed the scent anymore and have even grown to like it.
"overpowering scent you wouldn`t believe how fast we ada
I call it the "grandmamma affect".
You know, the tendency for older women to drench themselves in their "signature" scent. Because they have worn "Shalimar" or "Ma Griffe" for so long they can no longer detect at once, so they pour it on by the gallon it seems. In any event the result is same; best stand upwind and or near an open window if one wants to breathe.
