Very Interesting thread!
Nice to see a thread like this on here! Following on the above posts its suprising to see the variation of electricity different dryers use. The new Heat Pump technology really does seem impressive in terms of electricity savings!
The dryer I have, the Bendix 7442 is quite impressive I find, its maximum power consumption is only 2.3KW, which seems rather low to me as some other dryers seem to vary from this, all the way up to 3000w.
However where dryers are concerned I do think powerfull airflow is key, and goes to saving electricity also. On my dryer I mostly use the Half Heat option which dries most loads within 40-60 minutes which I find more than acceptable, high heat is only used if I'm in a rush. Would also be interesting to find out how many watts the machine is drawing using the half heat option, I'm lead to believe it would be roughly 200-400w less than the full heat option, but thats purely speculation
Drying using slightly less heat also helps with creasing I find, ever since I've had this dryer I've never had clothes so crease free out of a tumble dryer, same goes for towels - fluffy everytime whilst retaining the scent of the detergent they where washed in.
With my previous White Knight dryer I found that High heat would literally render
off the majority of the scent and also cause creasing and patchy drying, though I do believe these rely more on harsh heat than the airflow.
I do also have some experience using large capacity dryers at my local launderette (Gas fed, produced by ADC - American Dryer Corp.) I find these to be VERY fast however the heat thats used is far too much, when I used these most laundry would have literally no scent left at all and also be slightly rough to the touch due to the very high temperatures, but back then it was either that or wait for my compact White Knight dryer to work its way through multiple loads from my 6kilo Miele, and bear in mind each load in the dryer would be half the washers capacity, and take anywhere between 60-80 minutes to dry, which would in turn over-work the dryer and take an age to get laundry washed and dried.
Keep posting guys, always nice to hear a mix of opinions on here
