Rick
it was actually kinda simple, just had to try it different ways first, many failed attempts, but so far its working great, the first load did fill half way up the glass, even after I put it into spin after assembling everything.....from then on its working out quite well,
simple parts I had around the house...
--tubing- about 12 inches-same size as pressure hose
--an empty water bottle...about 10ounce worked best for me, use a nail and melt 2 holes in the bottom, and drill out the cap to fit the hose
--punching balloons, found at walmart, party section, 3pk about 2.50
--rubberbands
--"T", from an aquarium air pump
now I had a problem which had to be corrected, I used a piece of water line, 3inches, from a ice maker....slid this into the hose, slid balloon over this and rubberbanded it tight, the tubing prevents the hose from colapsing, and installed this in to the bottle, slid cap over hose and snugged in place, fastened this to the top cross member with tape......pulled off pressure hose, and re-installed with the "T" and a short piece back to the pressure switch.....presto, more water
the "punch balloons" are bigger and allow enough air to add enough water....the bottle prevents the balloon from over expanding....and for some reason it works best if installed at the top of the machine instead of the bottom...and I can easily re-connect the way it was, when I need warranty service...
but like I said, an added bonus was the distribution for the final spin changed...it used to take up to 10 of the 12 minutes juggling the load, and a 2 minute spin....now its almost the full 12 minute spin...never gave it a thought that the lower water level was causing the problem
alls I know is I am happy I finally got it to add water.....I was like Ralph, ready to chuck this damn thing out the window....but just the same, I would not get another frigidaire.....when I consider new machines, I take a screwdriver with me to open up the machine on the sales floor, if I can't make a screw adjustment, I don't want it!!!
