slowspin66
back to life
spinning to empty after the over flow rinse. All the processes are manual on this machine filling ….. washing… spinning etc. If you want to heat the water up you have to fill the wash basket first and then spin to save the water into the tub below where the heater is located…… when the water reaches the set temperature you have to set the machine to wash and turn the lever to let the suds return and hey presto the hot water returns to the basket for you to add the washing to . Fantastic little machine very simple to use and once have sorted out the camera will do a movie to demonstrate properly. The only thing i don't like are the black hoses which i have had to use as the grey ribbed hoses were almost impossible to find.
