Persil Universal Powder
@ jerrod6 hot water is 130F
which may also explain why your towels rinse better.This past summer has been warmer than usual 38-40 celsius so I used warm water since the cold water was not so cold, the warm water was warmer thinking it worked well, well at least I thought it did until I had the sudsing issue again.Seems the hot water did work, maybe once a month with hot water will keep any residue from building, it is worth trying to avoid the obvious.I'm also wondering if I reduced the load size if it would make a difference?
Funny part is I use the megaperls for colors on the colored towels with no problem at all, so are you using megaperls on your dark towels ?
