I think you call it . . .
. . . an H axis machine. The tub rotates 360 degrees and then reverses for 360 degrees. There is not much to see through the see-thru window except for the tub turning. And the water/suds will splash up on the glass blocking most of the view.
These machines were hard workers and had to be bolted to the floor because there was no suspension.
Jerry Gay
