whirlaway
Kenmore Seems Ok!
I use a 1955 Kenmore dryer with the matching washer as my everyday machines,it dries in about 35 min on med heat,its called a high speed dryer on the front top.It also has a basket type of lint filter you remove from the top rear,it sure catches alot of lint.I clean it after every load.No problems with it,buts it not as quiet as the 57 Kenmore I have without a lint filter,it also has a lighted drum and an ultraviolet bulb in it,the clothes smell so good and I dont and never have used fabric softeners or dryer sheets in either one.But it does have the same pulley set-up as the Maytag in the previous threads. Thanks!
