Do you suppose they installed it without bolting it down? Installing a bolt down machine on a wooden floor was something else. The installers had to drill through the floor joists then hold a plate under the joists and stick a long bolt through the plate, the joist and the floor above. Once the bolt was secured with nuts, the washer was placed over the bolts and secured.
