Dishwasher Smell
Can be solved by bunging a bit of baking soda powder inside at the bottom of the dishwasher. If one does this one can reduce or delete adding detergent for the first wash.
Frequently it takes more than one day for us to fill up and then run the d/w, and while there can be whiff when the door is opened, nothing otherwise that puts one off. Surely wouldn't bother using the "rinse and hold", as after several of those cycles things in the machine longest would probably be quite clean.
Good dishwasher detergent, plently of hot water and a good machine shouldn't have any problems cleaning any load that has sat sitting for <one week.
There must be something "not good" about the new versions of dishwasher detergents, I say this because sales don't seem to be going well. By eye-balling shelves at local supermarkets, the stuff does not seem to be moving. Finish gel which contains LCB, but no enzymes, has phosphates and seems to be selling, as do their tablets (STPP but no LCB).
While Electrasol (late Finish) tab are quite good in cleaning, they suffer from two drawbacks. Long term storage will turn the things hard as hockey pucks. This happens regardless of the fact each tab is individually wrapped, and where the carton is stored. While fresh tabs are easy to break apart, once they start to harden it requires a well aimed whack with a hammer to get the job done.
Other problem one found with Electrasol tabs was they tended to create lots of froth in my Frigidaire dw. This excess froth not only required an extra rinse (soap suds left after main wash), but was really hard on the motor/pump as they coped with all that froth.
In general regarding froth, noticed my dishes are cleaner with less to no "yibbles", then the detergent creates little to no froth so the full force of water can reach every where.
A few nights ago was overly generous with Cascade "Hydroclean" gel in relation to the load size, and by the second wash noticed the muffled sounds that indicate movement of more froth than water. So bunged a bit of silicone defoamer into the machine and viola, no more froth and things were back as they should. Next morning noticed my dishes were yibble free, even things such as cups in the far back corners of the top rack (yibble central).
FWIW, commercial dishwasher detergents seem to be immune from various local and maker bans on phosphates. May be worth it try to seek out restaurant or cleaning supply stores to see if they still have STPP laden detergents in stock.
Finally am totally gobsmacked in how quickly and totally Cascade and other STPP containing dishwasher detergents vanished. I mean *NO ONE* it seems has any stock left. It is as if P&G sent around armed men to forcefully remove the stuff. Even eBay, "NOS" central hasn't had a run of the stuff either. Makes one wonder just what was done with all the old product sitting on shelves and in warehouses.
