magic clean
- Joined
- Oct 15, 2004
- Messages
- 511
Ralph if I recall;
after a full fill, the pool of water in the sump should be up to the rim of or over the top of the fine filter under the hydrosweep. Perhaps someone can confirm with their KD-21 or 22 machine.
Knowing this, you'll have a good idea if you have a water level concern. Also, check the upper rack manifold (the soft rubber tube) that delivers the water to upper wash arm support. Sometimes it can become sticky,distorted or gummy reducing the free flow of water. (note the small weep hole should point down) Try to tilt concave bottomed mugs so as to reduce the amount of water that remains after the machine drains. This will minimize any grit that can collect.
all the best...LP
all the best...LP
