Requesting info on this vintage Maytag set
Marky_Mark
Aug 3, 2014
690
Living in Palm Springs and Madrid. From Liverpool.
Hi guys
This Maytag set is for sale near me.  It looks like they’re in excellent condition.  I don’t know much about them.  Are they good?  Would this washer and dryer’s performance and capacity compete with a Speed Queen or a vintage Whirlpool belt drive or direct drive set?
I believe the dryer has a moisture sensor. Is the washer long stroke with orbital transmission?
All thoughts (both good and bad!) and info appreciated.
My first impression from the agitator in the money shot is that the washer has the short stroke orbital transmission.  A serial number would help the Maytag experts to say one way or the other.  My A712 was produced in May of 1987 and was among the last to still have the long stroke transmission.
IMO, that pair is way overpriced unless they're as low mileage as they look.  The price can be justified when compared to the junk machines made today, but these show up on line as private party listings for a lot less money.  If there's a decent warranty and return policy, or if money is no object, then this set may be worth pursuing if you're not concerned about which type of transmission the washer uses.
The dryer is gas, by the way, in case that matters.
had that same model washer
At the house in Beverly Farms MA although the timer layout seems different as am almost certain the regular cycle was just past 12 O'clock and it had a built in soak as in you could fill by turning the dial one click and then it would sit with the timer ticking till it reached 12 minutes and then it would complete the cycle. It had a Kenmore dryer sat next to it a top of the line I believe the dryer had out lived 3 washers...
Austin
TOL Goodness
A712/DG712
Both look factory new and the washer tub/dryer drum both indicate very low mileage. The washer has the older, longer stoke transmission. Dryer is natgas and is equipped with a moisture sensor. The asking price isn't too unreasonable for being TOL units in that condition. You should be able to talk them down to at least $450.
Is this located in the states? Do you have access to natural gas?
Thank you for all the replies!
This set is for sale at a dealer in Long Beach, California.  I am in Palm Springs (about 2 hours away) and I do have both gas and electric hook ups.  But I would prefer gas.
I wasn't especially looking for a Maytag set.  But this set really caught my eye because it seems to be in such excellent condition and TOL (or near TOL).  I prefer the idea of the long stroke agitation.
I think I've read on AW that the washers are good but they don't cope well with large loads.   I have also heard that some Maytags can be rough on clothes with the Power Fin agitator (which I think this machine has).
Do these dryers work well?  Is the moisture sensing good?  It looks like I would have to dry loads using the PP cycle if I want to take advantage of the extended tumble phase.  So I don't know if the dryness level reached is the same on both the PP and regular cycles.  I see it has just two dryness levels: Dry and More Dry.
Looks like it would be a beautiful vintage set, assuming that this variety of Maytag is known for good performance...?
Excellent set. Bought mine in 1989 new. Real workhorses with no issues. Ended up selling them to the people that bought my house in 2001. Still wish to this day that I had kept them.
The question is how long you are willing to wait, how much time you are willing to spend searching, how far you are willing to drive, and whether you will hold out for a set or piece a set together.
$480 might not be a steal, but $300 and months of searches isn't necessarily a better value.
This pair looks to be in immaculate shape, and cost far less than any quality new set today. If they fit the bill, I'd say go for it (or make a reasonable offer), and spend the rest of your time on other things in life!
Thanks for all the info so far.
Another question: is it ok for me to transport them on their sides?
Are both the washer and the dryer generally good performers?  I am not washing particularly dirty laundry. But I would like the clothes to be gently cleaned and well rinsed. I also like to have a gentle dryer with accurate moisture sensing that produces wrinkle-free results as much as possible (drying speed is less of a concern). This set does look excellent and I would love to have it. But I have no experience of these machines at all.  So I don’t know what to expect.
I notice that the washer’s lid has no writing/instructions on the inside.  Is this normal or could this set have been refurbished/repainted?
The capacity of these machines are smaller than a modern Speed Queen toploader and DD Kenmore sets.
These SOH dryers work well and the moisture sensor is pretty accurate. On the D712 models, the electronic control dryness circuit is engaged at all times, even on the "Timed Dry" selection (this didn't change until the D713 models in 1989 and beyond). PP cycle provides a longer cool down phase with no change in temperature or dryness over the regular cycle. "Dryness" is strictly controlled by the "Regular Dry" "More Dry" selections.
These washers do fine with larger loads when operating properly; they're like any other washer out there....don't overload beyond its ability. Nothing but a Powerfin has cleaned my attire for 35 years and I still wear plenty of clothes going back to the early 90's although I try not to wear those older shirts in public anymore.
What in the pictures above indicates the washer has the long stroke transmission?  I recall when I was going after my A712, one picture provided a slightly from the side view of the agitator and fins, but nobody was sure which kind of transmission it had and I was warned that it would likely be outfitted with an orbital, which pleasantly turned out not to be the case, so to speak.
For future reference, I'd like to know how to so easily identify a long stroke 12 series machine.
These show on line as private party listings for a lot less
Personally, I've never seen a used TOL A712 set in such impeccable show room condition at any price.
I like bargains as much as the next guy but the chances of finding another set like that for less money is slim to none.
And I doubt the seller put much time into cleaning them up either.
Most used appliance dealers I've seen just do a quicky wipe down at best, slap on a price on it and put out for sale.
