Well as much as I hated to I returned the 542. There was nothing wrong with the washer. The problem was the amount of wrinkling that was present. This may be inherit with all TL's, not sure. In our home we hang dry a lot of outer wear clothes. With the extra wrinkling it created more work - ironing, spritzing with water and then placing in the dryer. The SQ was very fast with washing and I really liked the hot water setting. We tried all settings to reduce wrinkles, if we did slow spin then the clothes were too wet to hang dry. The dealer accepted the return after discussing the problem. So - back to the Frigidaire FL GLTF2940. I would still suggest a SQ if you use a dryer exclusively. Nelson
