So was I.
Then using a standard 120 volt 15 or 20 amp circuit to run these is not an option. I hope you not advocating that this be done, because it dangerous. A newer electrical system may might put up with this the plug and outlet less so but if this is something on its last legs there is a real risk of fire, less so if new but the risk is still there.
This appliance needs a circuit of adequate capacity regardless of how its run.
