Servis Twintubs...
Sounds very similar
To the hoovermatic which started to wash when a certain temperature was reached.
I tend to go by the old method, if it too hot to put my hands in , it's hot enough to wash in!
Servis Supertwin MKIII (3) Model 42 - Year 1966
This is the revamped machine from1971 with the new sleeker look, the controls are now located on the top right of console, this model still had the original washtub with Hi-Zone Wash Action, the panels are a lot thinner & the washdeck is metal with a painted finish...the spinner was a new designunique to this model, phase 1 was a wider shallower spincan with holes all over..., phase two was a large pearshaped spincan with a row of holes near the base, these only existed on this model!!![this post was last edited: 9/27/2011-18:10]
Servis Supertwin MKIII (3) Model 70 - Year 1970
This model has the re-vamped gearbox & Agitator, the new Blue Agitator with the Snap-On Power Fin complete with Lint Collector, the spin can was now made of vitreous enamel for easier balancing, the spincan has vanes in the middle & holes in the base and is seen in all later models... [this post was last edited: 9/27/2011-18:11]
Servis Supertwin MKIII (3) Model 80 - Year 1974
Withe the dreaded spin can lid double interlock, to turn off spinner, move arm on outer spin lid to switch motor off and activate brake, open outer lid, then slide lever to open inner spin lid, a right pain!!, this ones due a spa treatment those painted washdeck consoles didnt take kindly to hot water & detergent etc..[this post was last edited: 9/27/2011-18:16]
MK3 pear shaped spin can
Hello Mike if what you say is right and I am sure you are then someone must have changed the original spinner on Sybil as she has the pear shaped drum with 2 rows of holes so far up I have never seen it before.
I know my mums MK1 had a solid drum with slots at the top only my MK3 I had "and like a twat gave away" was also solid with a row of holes near the top maybe the ones I had were friday washers ????
Austin
Servis Supertwin MKIII (3) Model 110 -Year 1982
The controls now offer us, wash timer with a position at twenty five to for the electric pump, and the spinner offers us spin and pump, which means in this position and the lid open you can have the pump on for overflow rinsing etc...also you can drain all the water out of the spinner before starting to spin - less wear & tear on the motor & drive
That MK3 in the last post was my Grandmothers model when I was growing up. Loved using it, i remember the gentle ticking of the wash timer, washing the machine eat the sheets when you dipped one end in the wash. I also remember running like hell in the early years whenever grandma put the spinner on, wasn't too fond of the noise it made on start up lol.
I just had a thought, that machine was shoved in grandmas shed a back in about 1997 because it needed a new spinner motor. I don't remember it being moved while I was living in England. I'm wondering if its still there, that would be awesome to see again. Chances are my uncle will have shifted everything out of the shed but then again he might not have...Will have to see when i am there in November :-)
Matt
