Somebody Stop Me - Servel S-800A
58limited
Sep 27, 2006
2,209
Port Arthur, Texas
I just drove 75 miles to get this earlier today. The trip included a fun-filled hour dealing with a thrown power steering/water pump belt which also knocked the alternator belt off, but I got everything fixed. 70s era Ford trucks are easy to work on.
This is a working Servel S-800a. The ID tag calls it an RUS-800-800A but it looks identical to a picture on one of the flash cards that is in my 1947-9 Servel salesman's kit (this is a guess, if anyone knows better please tell me). The S-800A is basically a budget version of the S-800 (which is the other Servel I have): plain white wire shelves instead of chrome wire, plain drawers instead of chrome fronted, clear freezer glass instead of blue, and a metal emblem on the door instead of a plastic one. They were made 1947-49.
My S-800 is missing the freezer door. If anyone can help with that part or the ones listed in this post please let me know.
This S-800A is missing the half shelf that goes at the top of the fridge compartment and a"MEAT" drawer - same as the two bottom drawers but says MEAT on it. Also needed are one hinge cover and both stainless strips that go on the "feet" at the bottom of the fridge.
Another idea...
Try Todd (Washerlover) in Eureka, Ca. When I used to work up there long ago, Servels were still to be found as they were in use out in the boonies like south of Fortuna and out in the woods. The pot growers and other people who wished to live "off the grid" loved them. They also still show up as barn finds as the area was heavy farming. Todd may be able to keep an eye peeled in case one shows up!
RCD
Servel Customers:
Weren't always off-grid, counterculture types.
In their day, they were a luxury fridge, because of their silence. Mid-Century rubber technology meant that compressor mounts on an electric refrigerator could dry and crack, making the unit even noisier than a new one. Exactly as with the rich today, wealthy people then found that a lot of ordinary everyday things were too much for their pampered nerves to take.
Here's a shot of an S-800 in its natural habitat, Hollywood-style. It's from Alfred Hitchcock's Rope (1948), where it's in the New York penthouse apartment of two gay thrill-killers played by John Dall and Farley Granger, pictured:
Nice one, Goatfarmer.
I hooked mine up this morning and lit it up - it is cooling. the freezer is down to 43 F, will see how far it goes. It is very clean underneath. My other Servel has surface rust and it cools just fine, so I think this one will be fine as well.
I really need to disassemble the other one, the firebox was exposed to salt water during Hurricane Ike and the corrosion is getting bad. Now that I've mostly recovered from my neck surgery, maybe I can tackle it in the spring - I still have to go slow and work myself up to lifting and moving heavier weights.
Yes. There is a vent grate on top and they were meant to be hooked up to a flue. The S-800 that I found at the side of the road was repainted with a brush - you could see where they went around the flue when they painted. When properly maintained and vented they are quite safe. The problems with these fridges, and the reason for the government recall, were from being hooked up to poor or no ventilation (either by the appliance company's installer or by the do-it-yourself home owner) or due to not performing yearly cleaning and maintenance, thus allowing for toxic CO build-up in homes. Even if maintenance is not performed, proper venting should keep CO from escaping into the home. Today, one can install a CO detector to warn of problems.
My gas fridges are out in the garage which is anything but airtight.
Okay:
So, if I understand you correctly, this fridge had to have a flue coming out its top for correct installation.
That would mean that the photo I posted would have had the flue running through the cabinets above the fridge, had it been a real-life installation instead of a movie set, where the fridge was not actually required to work.
Other owners who didn't have cabinets above the unit would have had the flue visible, right?
Thanks.
