Speed Queen Dryer Lint (exhaust) problem. HELP!
danmantn
Nov 3, 2009
982
Tennessee
OK. I have enjoyed my new 2009 Speed Queen dryer. It's quick, hot, and does the job well. About a month after I started using the dryer, I noticed some lint buildup PAST the screwed down lint filter screen. Thinking it may be just some very fine 'pass thru' lint, I didn't think much of it, removed the screw, cleaned, and life went on.
Month #2, same issue, but I noticed considerable build up in the attached housing that routes to the blower motor. I spent an hour cleaning it and phoned Speed Queen. Of course, super friendly and not only sent me the screen to have replaced, but also included the attached blower housing in case I wanted to call service and have them put that on--the folks at SQ thought there may have been a problem with how the plastic came out of the mold.
I received the pieces (mistakenly in Imperial grey), but that was OK as I was just going to test and if that solved call and have them replace in white. It worked for the first few days, but as the plastic began to flex with the heat, the same problems arose.
I'm in month #4 and have put it in the back of my mind as something to address. I spent the good part of this morning cleaning this for the THIRD TIME. Review the pictures--all this lint that you see if from 2 loads per week! Last month I got so tired of it that I taped everything down with shiny tape that would seal out the air from the edges and withstand the heat...but even THAT didn't work as the tape eventually caved in.
Speed Queen has been using this design for an extremely long time. :( Surely I'm not the only one with the problem. The design (plastic touching plastic) certainly doesn't lend it's way to create a good seal...I would imagine a rubber or felt material should be here. Anyone else having this problem? I will call SQ on Monday to check as the next step. I just really hate having service people work on really new stuff for some reason. I'm am particularly concerned/pissed because I spent a fortune in time and money in cleaning the 18 foot exhaust pipe before I got the dryer as the fact that the pipes are in the wall and in a condo concern me for lint buildup.
Any suggestions? Pictures to follow.
Pic 2 - notice around the edge of plastic (where the filter is removed) the buildup in various places (where the plastic of the housing is gapped with the filter).
Other than getting out a glue gun, or insta-foam seal stuff...I don't know what to do. Seems if they replace this screen, I'll get the same result.
That is really odd. I've never seen this before. Mine doesn't do that and I dry 5 or 6 loads a week. I haven't cleaned anything below the filter in 2 years although I do check it all the time. I've never seen this in any of our customers dryers either. It's almost indicative of a clogged exhaust, but you said you cleaned it.
I would call SQ, see if you can email or fax the pictures to them. They are always very willing to help and want all problems solved.
I have a 26 year old Speed Queen Washer and Dryer. Since the day I bought the Dryer I have had this problem. I am one person and I do an average of 4 loads a week, but if I do heavy cotton towels or cotton scatter rugs, I would not only have to clean inside the dryer, but take apart the door because the lint builds up in a space behind the front door. Once every six months I would have to clean out the exhaust pipe going outside. My dryer is electric, but I tend to think it is a design issue with the filter screen. I have noticed that the screen is not as fine as other dryer screens and it doesn't snap in to a slot where there is a rubber gasket or seal surrounding the filter, it just sits on top of that space. I just bought new cotton towels and in the middle of the drying time I had to clean the filter and take apart the door and vacuum out the inside where the filter sits. I long since stop using the dryer because of energy consumption so now I hang them in the basement, I can do that because I live in a house. The dryer works just like the day I bought it, no problems with the operation only the one stated. You can try to get a thin rubber seal or weather stripping and place it around the space and then snap the lint filter back. I just so used to cleaning it. The washer I only change the pump, water intake valve and the brake pads last year, not bad for 25 years of use. Speed Queens are great well built machines, very reliable. I would most likely buy another one because of the reliability and the quality.
I use a big bottle brush with a long stem...
every couple of months. Mine is an older model with the slide-in screen and, when I remove it, the interior of the air duct leading to the blower looks just like the above pictures. All I do is brush the lint off the sides and down towards the bottom of the duct. Then I turn on the dryer for a few seconds and all the lint is expelled through the exhaust vent to the outside.
I've been doing this for years now and it works fine. Last year I had to have a drum roller and the blower motor replaced. This afforded me a good look at the dryer's interior, which was very clean. The blower is very powerful and able to expel the excess lint once it is brushed off the sides. Only thing I've got to not do is accidentally let go of the bottle brush when I clean out that area.
Olav
I guess the visible stuff is the lesser concern...what concerns me most is how much is building up in the 17' of pipe that leads to the roof. That was a PITA to clean, and I would rather not increase the number of times it a year I have to clean that--of course the warnings of dryer fires concern me too.
Should I get the caulk out now? :
The lint that builds up around the blower duct is only fine and sticks to the condensation that occurs during drying, then keeps catching and building on what has already accumulated there. You will find that the inside of the venting pipe also develops a coating of this fine lint over time.
Mine is a flexible 5' pipe that only extends from the side of the dryer to the window. I can pull it off the dryer outlet and check for accumulation without much trouble and there is never anything much to worry about.
Anyhow, when I do what I've described in my previous post, I can see the lint blowing out of the vent.
The blower is probably powerful enough to push small wads of lint all the way up a 17' venting pipe, but you probably have mesh covering the pipe exit on your roof.
In your situation I would pull the dryer out in six months or so, to see if there is major accumulation building up inside the pipe. Is it easy for you to check the pipe where it exits your house? I would probably do that once in a while as well, just to make sure.
In addition to the 17' dryer vent, I also have to use this device (periscope) to get the exhaust to the left of the dryer, then another piece of hose to get it to the wall. The idiots that built this townhouse did not even make the closet large enough for my Whirlpools, and the deeper SQs made the problem worse by 2". I had to remove the doors and readjust the tracks for the bi-fold doors. Would this cause any issues? I had to duct-tape the seams in the periscope as it would allow lint to fly all over the place with a gap here or there.
Too many turns
are probably contributing to the problem. Each 90 degree bend is equal to 5' of straight duct run, and 45's are equal to 2.5'. You have 4 90's within view (in just a few feet of run), and I'm sure more that are concealed in the wall or ceiling. Most codes restrict dryer ducting to the equivalent of 25' of straight run, unless the dryer specifically states it can have longer. You've used up your alotment just in the bends. Plus the flex duct is not smooth like sheet metal would be, and that just adds to the resistance in airflow.
What would a solution be? I have 2" of space between the dryer and the wall. Not 2.1, 2.0" exactly. From the other posts, sounds like this is happening to other models without any restrictions such as mine.
A tough situation
The vent connection being on the side makes me think that the wall behind the dryer is probably solid masonry, precluding going up through it. I'm assuming this model dryer has no provision for side venting (there would be a knockout on the side like my Maytag DE406 has), but cannot tell from the pic. If not, I truthfully cannot think of anything you could do that doesn't involve doing demo and quite a bit of construction, something I seriously doubt you want to do in a new place. I would imagine the other units in the complex are built the same. Have you talked with any of your neighbors about how they dealt with this issue? Wish I had a solution for you.
If you put the dryer against the other wall you could do away with the side vent altogether.
Speed Queen Dryer Exhaust
I don't know how the new Speed Queen dryers are made if there is a knockout on the side, however, on mine there is on both sides including the back where I have the exhaust. In my instruction manual when I bought the dryer, there was a kit that I could have ordered to do a side connection. I wouldn't worry about a dryer fire at this point. That usually happens when you never clean out the dryer for years and the lint comes in contact with the fire box if it's a gas dryer. I had a Hamilton Gas dryer many years ago and I remember cleaning out the pipe going outside which took years to build up with lint. As long as you maintain the dryer every so many months cleaning out the lint buildup, you will not have a problem. I still think it's a design flaw with Speed Queen dryers.
