directdriver
Model: AFNE9BSP113TN01
Serial: 1506004269
Hello adding some info that may help others diagnose the issue. I have the above washer also experiencing problems with the 803949 board. Most of the time the machine will not power on with no lights on the digital controls. Occasionally works fine. Removing the cover and looking at the back side of the user interface you will see a small red light indicating there is power to the interface. My red light is on when the front controls do not work. There is an 8 pin connector you can unplug to check if the inverter board is sending the correct voltages to the interface. Red/white = 12v, gray/white = 5.5-7.5. Mine measure 14v and 10v. The gray voltage out of range causes the interface to not work. Speed Queen tech support helped provide this info. They will not help with a replacement board however.
Serial: 1506004269
