What do the timers do? Switch stuff.
This board does an f ton more that just switch this switch that.
Comparing apples and oranges sure does work, right?!?
Hi, I am new to the forum but noticed other people have had the same issues with speed queen boards.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?77855
Looks like there was a bad batch of boards. How do I tell if mine was part of the bad batch?
ATEE9AGP173TW
Serial is 1511010527
Error code is ed44. Alliance/SQ says that is the 803949P which was replaced with 807175P. This part is clearly made of unobtanium since the quotes for a new board are about 850 to 1200 dollars. My unit is a few months past the 5 year warranty mark.
Board repair seems like the only viable option, though getting anyone to work on a speed queen is hard.
Has anyone figured out how to tell if these are from the bad batch and push the repair back onto speed queen for selling a lemon?
Hello everyone,
I'm an electronics technician from Greece working on repairing a Speed Queen control board, part number **807175P**, which seems to trigger error code **ED44** (Drive Brake Fault).
Unfortunately, I only have the board and not the full machine, but I’ve managed to do several tests:
- The 220 V AC input is correctly routed, and I’ve verified that the board outputs:
- **+12 V**
- **+5 V**
- **+3.3 V**
- All these voltages seem stable.
- I’ve also traced the inputs that signal the relays to activate the door lock, and they respond correctly.
- However, the board’s power LED does **not** light up, even though all the voltages are present and clean.
- When powered on the bench, the board does **not** fully boot, and I suspect that ED44 may appear due to either:
- lack of communication with other modules (motor or interface board), or
- an actual internal fault (possibly firmware-related or a damaged driver IC?).
I’ve inspected both 803949P and 807175P boards and they seem **identical in components**. Does anyone know if the only difference is software/firmware?
**My questions:**
- Can ED44 appear simply because the board is not connected to the rest of the system (motor, inverter, etc.)?
- Is there any known failure point (e.g. a blown gate driver or feedback issue) that commonly causes this?
- Does anyone have a partial schematic or pinout of the motor/inverter communication lines?
Any help or insight would be greatly appreciated. I’m trying to fix this for educational purposes and to help others locally with these boards.
Thanks in advance!
