The title is my humble opinion for the time being, depending on how my stubbornness wants to play out xD.
My family bought a speed queen washer, thanks in part to Youtube user DanManTN showing how this washer takes after older machines being simplified enough for old farts, while tending to fabrics with care with a more classical method of agitation.
This machine replaced the Whirlpool washer we had since we tossed our Kenmore BD after the motor went up in smoke a year after moving into our home. I still recall my brother having difficulty with his "Th"'s saying, "it has a squirter sing, to squirt!" However mom got aggravated with the machine stinking up the clothes with mildew and mold as the machine would neutral drain leaving a ring of scum at the top of the machine. So here came the Speed Queen to save us some grief.
To put it shortly, mom digs the new rig, and it hasn't let us down yet....Now if I could recall when we got it...
The only personal two downsides I have to this machine is the center seal that is destined to go bad, and the factory maximum water level setting. The washer only fills about 3/4 full on the maximum setting, and if you were to adjust this, you would have to turn a bolt on the water level switch located inside the control panel. To give folks a harder time adjusting this, thread locking goop has been placed on the switch to hinder folks from adjusting the water level switch. Pure aggravation if you ask me...I adjusted it tho, carefully.
The reason for this title, is because I feel that other brands have totally abandoned a sense of "simplicity" and added complications that hinder the cleaning of clothes, and make it more difficult for some folk to use.
Whirlpool/Kenmore totally abandoned their DD model only keeping the top end portion of the machine, and introduced a new motor/drive-train mechanism which is a great idea in terms of updating their older design. However, this is hindered by the suspension design where you can give this machine whiplash with the touch of a finger. Tuber's have complained at the machine taking far longer to complete a cycle as a load goes out of balance much easier than it did with the direct drive model (To compare, our Speed Queen barely went out of balance upon washing two heavy machine washable pillows). You also cannot let these machines fill with the lid open, as they must remain closed, and the automatic water level sensors have been problematic for some YouTubers clothing too.
GE has had its fair amount of issues with its electronic control boards causing malfunctions with their machines. One tuber I am subscribed too has an issue with a mode shifter causing the spin basket to turn during agitation - a flaw in the electronic control board.
Speed queen seems to be the only modern washer (correct me if im wrong) to have mechanical timers, switches, etc. As other modern washers are fraught with proprietary control boards which are expensive to replace and are unrepairable upon failure. Although a front loader - I recall repairing a friends Maytag Neptune with an irreplaceable blown fuse on an electronic control board, which required DE-soldering the bad fuse, or replacement of the entire control board.
So after this two hundred page ramble session, would you say that Speed Queen is the only "Sane" washer left?
These are just my opinions, I am an old man stuck in a young guys body, so I can be pretty grumpy at some modern devices at times
