Starting 'May Is Maytag Month' with a bang!
Power Fin in an A700
Yep, my A700 lost its original Bakelite agitator at some point. The replacement is a black Power Fin with a 1979 date on the bottom.
Dave ... I don't have one of the power fin (I should get one; forgot, I guess). But here's one of the original bakelite before it was even used.
The original bakelite agitator is quite powerful; the recirculation portion on the bottom "pumps" water that is in the agitator out. Sort of like a "burp", but only under the water!
It can create a lot of suds; especially with vintage detergent.
I think these are great machines and who ever ends up with the one that RCD found, is going to be happy when they get it repaired!!
WARM RINSE SPINS OUT MORE WATER?
Try rinsing the same load in cold water and then in warm water and weigh the load each time I don;t think you will find much if any difference. The human hand cannot feel moisture but it can discern temperature and items that are colder we tend to think are wetter. Raising 20 gallons of cold Minnesota water in the winter which can be around 40F to 100F uses a lot of energy more than enough to run a classic DW through a full cycle or a new energy star DW through two cycles. I am looking forward to seeing all the Minnesota folks and everyone else at Robert's wash in see you then.
The worn portion of the lower porcelain basket is a dead giveaway of repeated overloading techniques. I have a '65 A702 that saw much, much more use/abuse and the tub is still near perfect. However, I knew the original owners and their laundry habits. All washes were properly loaded, if not slightly underloaded.
if you think my more than 40 EXPERIENCE years are wrong
Well, my 50 year old towels in the hall closet coupled with my nearly 20 year old clothes prove (to me) that long stroke Maytags aren't as aggressive as you claim. Actually, you are the only person on this site (that I have known of) to claim long stroke Maytags have a harsh washing action. Not to be an asshole, but that kinda sounds like your opinions are clouding the truth.
Further I tend to trust Maytag and thier engineers they are the ones who changed to the load sensor agitator for there dependable care washers they did a lot more testing than either one of us.
Engineers changed to the load sensing agitator with the orbital transmission because of its fast agitation speed that was harsher on clothes and had poor turnover in a fully loaded situations. The orbital trans was used because it was cheaper to manufacturer than the pitman trans, and had a couple of less moving parts. It was also serviceable without requiring a complete tear-down of the machine. However, those points don't prove it's a better design, especially in the long run. Orbitals wear out the lower o-ring seal faster than the older transmissions and replacing the lower o-ring in orbitals doesn't guarantee a leak free operation after replacement. Also, they like to shear the pin and wind the agitator and upper shaft right out of the transmission, requiring a rebuild. It also didn't help th fact that most orbitals used the inferior triple lip seal that lasted an average of 5 years, compared to several decades, like the older design. The fact that most orbitals didn't have a lint filter in the agitator is just icky to someone who has 4 pets.
had far more complaints about MT dependable Care washers than any other brand when it comes to performance issues.
So, I guess the all of the high ratings that long stroke Mayatgs consistently received via Consumer Reports (long before the days their opinions became skewed) and the millions upon millions of happy customers that paid BIG $$$ for those machines are all full of BS then?
To me, it sounds like the complaints you got were from those who were "stuffers" and didn't know how to properly load a machine. They are a common breed in society :) I have used several other washers and never was much impressed. The only machines I haven't played with a lot are belt drive WP/KM machines. However, my parents had a coppertone belt drive Kenmore for a short period time when I was 5 and I remember my mother commenting how, once the KM died (it was less than 7 yrs old) the "new" Maytag (the very machine I still have) exceeded the Km in washing performance and especially drying performance with its faster spin. Also, no more frequent out of balance issues with the Maytag that the KM had.
Absolutely true.If a Maytag is not stuffed,they wash just fine,and are DEFINATELY more gentle than the DD Kenmores. Maytags with the Helical Drive are the best washers all around. They're not as fun or flashy as some others,though. And the one weakness they had was that you could'nt stuff them and expect good results. It goes without saying that no washer should be stuffed anyway!
