Unusual parts found in the bottom of a KDS 21 KitchenAid dishwasher
I can’t identify those parts from the picture. I have no idea if they’re even part of the dishwasher. What kind of metal are they made out of they look more like some sort of hard plastic or vinyl material that got hard.
Hobart designed KitchenAid dishwashers never used a brush motor and they never used a capacitor run or capacitor start induction motor either.
They used a fairly standard type of split phase motor early ones used to start relay, and then they went to an internal centrifugal switch and by the 21 series they went back to an external start relay.
This type of split phase motor tends to be very reliable while being very inefficient uses a lot more power than necessary for what it does. They tend to put off a lot of heat because of the inefficiency.
Hobart KitchenAid dishwasher Motors always used ball bearings which tended to be more accurate so the seals lasted longer as result. Hobart Motors also had a stainless steel motor shaft which made the pumps much more rebuildable.
About the only other dishwasher with a split phase motor that used ball bearings was whirlpool however, whirlpool did not use a stainless steel shaft.
One of the things that made D&M dishwashers so bad was the sleeve bearings in the motor which is kind of crappy when you get a motor that’s running 3450 RPMs, GE‘s cheap sidewinder dishwashers also just had sleeve bearings along with many other brands of cheap dishwashers.
John L
