Stoves without thermostats
Building an oven without a thermostat
Is just plain stupid, If it was designed so it could never go over 500-600F it would be nearly useless for baking or broiling.
It would not get hot enough to broil well.
It would take too long to preheat for baking.
It would end up using more energy because it would take so long to preheat and then eventually overheat.
It would bake very poorly because it could not recover when food was added and would result in too much temperature fluctuation, a decent souffle would be impossible.
It would be dangerous as many foods would eventually catch fire, and wasteful as much more food would be ruined.
Yes at one time both gas and electric ovens were built without thermostats because thermostats were expensive or not available at a reasonable cost, these ovens were more powerful and could easily reach temperatures over 700 F quickly.
Many of these early ovens were destroyed by forgetful users, or the fire department when they responded to a fire, LOL
Underwriters Laboratories would never allow such a thing to be built and sold with their approval and without the UL sticker, they cannot meet requirements for sale because sellers have to be responsible for selling safe appliances just as manufacturers have to be responsible for not building and marketing dangerous appliances. Fire insurance companies would not insure a building with one in it. The concept is a fever dream of one who knows little of reality.
Knapp Monarch, Toastmaster and other brands made their cheapest models of table toasters without thermostats, but they were minimally powered units used with supervision. If you are interested in studying about these devices, the magazines are available.
Food catching fire
Not if you turn down the heat. Set to preheat- then turn it down a few notches. Even if left on preheat mode the elements would not be strong enough to push it past 550*F.
Preheating will take time though I can not deny this, and yes food will lower the temp taking time to recover.
But if played right I can see it working reasonably well.
Perhaps it might be time for me to look into PTC technology.
Just to throw this out here, I was thinking about this thread and came up with an idea. Would not it be just easier to take a more "modern" stove and remove the temp control and add in 2 burner controls, one for the bottom element and one for the top element. You could control the amount of heat being put out by both with the burner controls and adjust as needed. Just a thought.
Jon
Its a good idea, thank you! I intend to try a variac to get the exact wattage that will stabilize a temperature, but before that I would need to improvise so your idea and combos idea would work out well. Wiring the bake and broil element in series would work to in giving me a lower wattage and going from there.
The helpful folks aside... considering that Tomturbomatic is now at 2 likes maybe its better that I don't share these ideas with the world. People come here to escape the judgment offered by the public, only to receive it by a certain group of inviduals on here.
Don't take it that personally, it's more just that you're requesting information/assistance toward making a product "worse", which is a difficult ask for others to provide helpful advice toward. It might make sense to you, but to most other folks, it's just hard to understand why you would want to do this project at all.
People are free to think its a bad idea warranted or not as much as they want, but can reserve typing out personal attacks. Yes it says more about them then it does about me, but for a place where its supposed to be safe to share these ideas it becomes rather disheartening. Yet ironically I would think (expect) thats why those people are here- to be safe from judgment.
Sure in some ways a thermostat free oven is a down grade in performance, but in other ways its a plus, good enough that PRC is doing it today. Then there is also the fact I want to see why this is a bad idea for myself. A lot is learned in the process like thermodynamics, series/parallel circuits, math, ect. "Violating" the "norm" should be seen as a good thing.
Hi Chetlaham
This won't answer your questions, but does show a example of a gas stove (currently in use) that has no thermostat.
(Original question)
The oven has one valve to open to control flame.
The # of jets for oven flame probably equal to two stove top burner jets together. I never open this valve all the way because I fear flame is too much to fast. During preheating, and If not babysitting, oven temp can easily reach 600 degrees in 15 min.
I'm so use to this stove.. I really don't think about it much because I just kinda know what flame height gives me 350 degrees. I also hang a oven themometer for accuracy.
Since the broiler is directly under the oven flame, time and temp is regulated by raising or lowing what ever one is broiling to that flame..instead of raising or lowering oven flame.
It's all very low tech, but would be considered unsafe by today's standards..(As it probably should be) but works just fine me!
Well at least web page of one. But I wish to try this on a modern GE/Whirlpool/Frigidaire oven. I have a feeling convection will make work.
I see a thermostat on these to the left- does it actually control anything? Is there an instruction sheet to this oven?
And is 120 applied any time to the elements?
RE: Reply #46
No, you did not find an oven without a thermostat. The chrome object on the left side of the oven is the thermal control. It turns the heaters on and off to maintain a set temperature. The switches vary the intensity and balance of the heat for various cooking operations. Roasting meats, for example, called for top heat set at medium to give browning of certain meats, while a large turkey roasted over several hours might only require low top heat or no top heat to protect the delicate breast meat while baking called for low top heat to produce delicately browned baked goods like cakes and biscuits.
If you want to see an oven without a thermostat, go to thread 80017 in the Imperial Section, offering Launderall Model LS1 machines, Post 1039449, photo 4 of 7. Behind the washer is a Westinghouse oven with a thermometer mounted on the oven door. You can easily find this by typing Launderall into the search box at the top right of the Imperial Section and choosing the thread.
"Westinghouse does not have a thermostat to cycle the current"
Which would indicate multiple wattage settings I think. Ie something like 1,200 watts to preheat, 675 watts to hold a steady bake temperature.
Perhaps, although your wattage ratings are very low for a 240 volt oven. Why not preheat on 3000 watts at 240 volts and then drop the voltage to 750 by dropping the voltage to 115? That early 1920s range with just a thermometer in the door for MONITORING THE TEMPERTURE was upgraded by the later 20s to various thermostatic controls for the oven so as soon as there was technology for AUTOMATICALLY CONTROLING THE TEMPERATURE of the oven, the non-thermostatically controlled ovens were a thing of the past.
Without the literature for the range with the non-thermostatically controlled oven, I cannot say how the oven heat was controlled.
Preheating at 3000 watts
Is doable, however if left in pre-heat mode the oven could over heat going above 600*F. Opening the door could result in user injury. Which is why the door is locked during self clean. With a lower wattage the oven can't over heat.
Just entering some numbers for future reference:
(@ 240 volts, stabilized steady state)
350 watts= 164.57 ohms
650 watts= 88.6 ohms
1000 watts= 57.6
310.77 ohms all 3 in series = 185.346 watts
Position:
1) 185 watts
2) 350 watts
3) 650 watts
4) 1,350 watts
5) 1,650 watts
6) 2000 watts
7th position could be added for 1000 watts only- not sure why it was never added.
