Here are Two of the Posts
that indicate the warm setting on the C50 does in fact heat. The first states that it keeps the coffee hot for an extended period of time without burning it. Something that wouldn’t be possible if the warm setting effectively turned off the current.
The second post goes into detail about adjusting the thermostat on the C50 to shorten the brewing time, something that is controlled by the warm setting, and how much heat is in the lower chamber, As we all know the temp must drop low enough for the draw down to commence.
I really have no desire to continue this exercise in futility. Launderess, if you do have the owners manual for the C50, if you could kindly post it, as it is printed, the mystery could come to an end. I still contend that Sunbeam would not have labeled the switch “warm”, if it in effect was actually “off” as you interpret the directions. The directions that you transcribed were vague and contradictory, and open for individual interpretation.
And please, understand that I mean no disrespect by my seemingly ceaseless questioning. But like Judge Judy says, “If something doesn’t make sense, its likely not true.”
Eddie
Jim Black/Factoid
Posted September 16, 2017 at 2:38 am | Permalink
Shirley,
I use five coffee scoops (1/8 cup, 2 oz, 4 Tbls each) for a full pot, and never brew a half pot. You will find, by the way, that Coffeemasters keep the coffee hot for an extended period without burning it. The C30 series is very good at quickly reheating a half pot while keeping the taste quite good. The C50 will keep coffee hot, but takes a half hour or more to heat it up. I’ll explain the reason for that last if anyone asks.
The grind to use always depends primarily on how long the infusion time is. If the grinds will be in contact with the water for a longer period, then a courser grind can and should be used. The infusion time on these pots varies a bit, but is usually on the longer side. Assuming this is true for your C30A, a somewhat coarser grind would be appropriate.
The other factor affecting the grind is how fine the filter is. The C30C has a stainless steel filter which is easier to clean, but is not as fine as the cloth filters used on the original C30. If I use a fine grind in my C30C, there will be a bit of “fines” in the bottom of the pot.
Note that the infusion time on the C30 and C50 series is adjustable. See Jim Lauck’s excellent comment above for details.
Jim Black
Posted May 13, 2018 at 2:40 pm | Permalink
Those directions are in a previous comment from Jim Lauck. Here is a re-post in full:
Jim Lauck
Posted January 14, 2017 at 11:28 am | Permalink
A comment about brewing time on the C50: It is adjustable. There is a hex head screw in the base of the
unit. One must first remove the bakelite base from the lower bowl. Remove the hex screw in the middle of
the bottom. Then you must remove the two hex nuts from the electrical prongs. The bakelite base will now
slip off. You will see a 6-32 machine screw with a hex head on the contact assembly. Turning this screw to
the right pushes the contact assembly closer to the bi-metallic strip and shortens the brewing time (shuts
off faster). Turning the screw to the left (counterclockwise) lengthens the brewing time. I recommend
turning the screw only 1/2 turn at a time, putting it all back together and do a test run with only water. My
C50 pushes the all the water up and switches off within 5 to 10 seconds. It pulls down in less than a
minute. Bought mine at the Salvation Army for $1 in the early 1970’s. If you take care of it, it lasts forever
and makes great coffee.
Reply
[this post was last edited: 5/17/2019-02:17]
