The Cool Wash Temperature
Cool
I find it half way useful, though rarely used it. The average person likely would use it frequently. The GE TL we did have at a rental for a brief time had it. The ATC was a more appropriate temp versus cold, and did not fill with tap hot like warm setting would at times. My grandparents Maytags have it as well, but just adjusts amount of time spent filling with hot water rather than a goal temp. Most here won’t use it often, but still a decent option to have.
Fact is many US users wash in tap cold water.
That worked well with non HE systems.
But with the very little water newer machines use, adding even a bit of hot water can make a HUGE difference.
I think GE has had models in the past that had tap cold, cold, colours cool and brights cool before even getting to warm.
Now they have either Tap Cold or Cold Plus (which appears to be similar to LGs ColdWash setting, so tap cold with additional wash time basically) on any machine.
Then cold, cool, colors (or mild on some models), warm and then hot.
Whirlpool sticks with Tap Cold, Cold and Cool.
Many others and especially TOL machines no longer label anything between cold and hot - just different levels close to either or.
Heck even Miele dropped warm to 86F and shifted 104F to "Warm+".
Found that what would equate to cool or such (20C/68F) with a longer wash or a soak works really well for outer wear like jeans, sweat pants and hoodies.
With a good enzyme detergent the typically light, less hygiene dependent nature of that cleaning job works great.
I still use at least 86F usually, but low temp washing can be an option in certain contexts with little to no drawbacks.
In the Northern part of the US tap cold water can be near 32*F during the winter and near 68*F during the summer. Having the ability to add hot water during the winter on a cold wash is of a major advantage. During the winter when washing delicate items I will often let the washer fill with a bit of warm water before switching to tap cold. My washer does not have a 3 coil valve, ATC or a thermostatic inlet valve so its either a 30/70 warm fill (~90*F tub temp with a 142*F water heater temp) or tap cold. Cool makes a difference and if my machine had it I would use it.
Low/Mid end TL GE washers at one point had a triple inlet valve system:
Cycling the right valves gave cold/cool/warm and hot. I like this concept and thank GE for doing it on their BOL and MOL models.
Cold-Water-Wash-Technical-Brief
"Household hot water wash temperatures in the United States are determined by the
temperature set point on the water heater. The U.S. Consumer Product Safety Council
recommends that water heaters be set to 120ºF in order to avoid scalding household
water users, which sets the upper limit for water temperature in a household (CPSC,
2012). “Cold” water wash temperature, referred to as “tap cold” on some machines,
is the inlet temperature of water delivered to a residence from the water mains.
The actual temperature of cold water entering a household varies significantly based on the source of the water (e.g., on-site groundwater well versus public water supply), the time of year, and how deep pipes are buried between the source and the residence.
The average inlet temperature can range from 37ºF in Anchorage, AK to 82ºF in
Phoenix, AZ (GTX Technologies, 2001). The scale of potential temperature variation
is reflected in Figure 2, which shows how average groundwater temperatures vary
across the U.S. These values do not necessarily represent water temperature in a
residence, as noted by the delivered temperature to an average household in Mesa,
AZ, a suburb of Phoenix. Figure 3 further underscores the difficulty in accurately
describing household cold water temperature by providing the temperature of water in Phoenix, AZ over the course of two years when stored at the surface or conveyed to a household in pipes at three different depths (Burch & Christensen, 2007)."
https://www.cleaninginstitute.org/s...ts/1/Page/Cold-Water-Wash-Technical-Brief.pdf
Carry on...
reply #13, GE LAUNDRY:
I think that would be the problem you'd have if you're using Tap Cold--making the water the same as what comes directly out of your faucet but isn't that what Cold wash/rinse is anyway?
-- Dave
Reply 13- That is the whole point of cool wash. Say that you have to wash delicate colors. You have Tide Professional. Its winter outside, tap cold is somewhere at 40*F. The water is really cold. Cool wash lets detergent work by adding a little bit of hot water to the wash water raising the temperature to say 65*F. Cool wash is not ideal for towels, sheets or whites however cool wash is a much better alternative than tap cold water when washing colored delicate items. you get the advantages of cold water without disadvantages with really cold water. Basically raising the water temperature just enough so that its not super cold but not warm either.
<blockquote>The average inlet temperature can range from 37ºF in Anchorage, AK to 82ºF in Phoenix, AZ (GTX Technologies, 2001).</blockquote>I have measured initial tap-cold at the 90°Fs in summer ... considering the route from the well-tank in my not-climate-controlled detached garage and through the house attic to the target faucet ... until it reduces after some minutes as the attic lines purge and the tank is refreshed from the pump feed which is a long route from the well at front right corner of the property through a buried line that runs around back of the house to the garage on the other side.
Reply #17
Right, where there is permafrost (AK) the temp will be lower. Wherever it freezes, we do not run pipes above the ground. Even most hot states don't do that. It's not up to code.
6-8ft under ground, is 55 tp 60 degrees across most the United States. Poorly designed systems are an anomaly.
