richardc1983
The other week before my holidays the pump motor appeared to have jammed I could hear it humming. I thought maybe something caught in the pump so pulled the machine out and turned the fan round on the pump and it moved ok and smooth so started it back up and it pumped out fine and ran ok for the rest of that week. Bear in mind this pump has always been noisy but has done its job since I got the machine.
Anyway after 10 days holiday I came back last night to the boiler breaking down ( from 33C heat in spain to 10C UK weather I wanted a hot shower) and thought I would put a wash on (first holiday wash). When it came to the drain stage I noticed the machine is not emptying but trying to spin full of wate with the pump just humming. Not good being 1am I turned the machine off and decided to call it a night.
Got up next day and pulled the machine out this time the pump seems seized/stiff to turn with a small pool of water under the pump and the pump housing rusted so it appears the bearings/seals have gone and leaking water which have in turn corroded the motor and seized it.
Anyway onto ebay I went and bought a new pump with the red cooling fan for about £13 and will fit when it arrives. I assume this is easy to swap out? Do I need any special tools, does the pump just screw in or is it bolted in? Know I will need to remove jubilee clips and get all the water out... flooded kitchen
Least the new pump will be quiet like!
