Hotpoint 95622
Hello all, I had one of the Hoover dishwashers and only replaced it 7 years ago. The round baskets pull out and will come apart ( top and bottom ) cutlery in the middle grey baskets, plates and bowels in the top, mugs and pans in the bottom, and the unit is turned buy the pressure of the water jets which are in the top right and bottom right, very small spray arms so turn the baskets to make sure that nothing is sticking out and stopping it moving and try to balance things out so the weight is even. The heater in under that round filter. You put the powder in a little dispenser that hangs from the top basket on a hook and the base of the dispenser has chains as it drops of the bottom when the water gets hot releasing the powder, you have to hold base in position then press the black button inside though the twist off side cap, no salt is used as no water softener unit, rinse aid is put in a little pull out filler at the top of the machine, the reservoir last for weeks, if it works it’s a fun machine, it washes and then rinses and then fill and heats the last rinse so the items get steamed first. Mine rusted badly in the bottom and was past repairing. P.S. there is a vent at the top and clouds of stem will bellow out which is fun too.
Lee
