thatwasherguy
Hi! As you may already know, I have a 1978 Maytag A-208 that I recently restored. I’ve used it for about 30 cycles or so, and it works beautifully. I also have the matching DE-408 dryer that I’m almost done restoring. I have one problem, however. I don’t have room to keep them at my house at the moment. They will have to sit in a storage unit for an extended period of time until I get room for them. Apart from fully draining the machine, and removing the springs from the motor carriage, is there anything else I should do for the washer, such as filling it with a little antifreeze? Also, is there anything I should do other than filling it with hot water and letting it soak for a while when I take it out of storage? For the dryer, is it necessary to do anything except remove the belt to store it? Is there anything special I should do when I put it back in service?
Thanks,
Thatwasherguy.
Thanks,
Thatwasherguy.
