todays POD
Frigidaire 1-18 washers made by GM with the fabric program switch had the cold water option switch. It goes back to the solid tub machines with the fabric program switch. My 1960 Custom Imperial had the cold water options switch. This WCI (manufacturer, not model) piece of crap that was Frigidaire in name only merely continued to offer the cold water option. Less deluxe models in the GM lineup with independent wash and rinse temperature settings allowed for setting a cold rinse with a hot wash also. I can't speak to the WCI offerings; there was no reason to be curious about them. They were beneath contempt.
Truly A Sad Washer and Dryer
If someone gave us a pair of these NIB I would not keep them for the museum, even worse that the washer these WCI dryers were absolute JUNK, I remember a customer that [ thought  ] she got a good deal on one of these dryers, she had me connect it up and when I pushed the start button the machine started to shake and rumble and WALKED a foot out from the wall. It calmed down with a load of wet clothing in it somewhat, but the customer learned her lesson and ended up buying TWO pairs of electronic WPs from us, model LHA9800 washer and LHE9800 dryers, one set for each house, after we gave her a deal on a returned LHE9800 dryer and she immediately saw how nice a real dryer was.
You are right about that!
I remember when White Westinghouse bought out Frigidaire and started making these. The only thing worse than the washers were the dryers! They were terrible! Not that the GM Frigidaire dryers didn't have their own issues, but these were just awful machines that never held up in service for very long. Very poor machines that required constant repair until the owner finally got tired of it and ditched them for a Kenmore set usually.
WH model
I forgot to mention that I did have one of the WH model washers. It seemed more of an old Franklin design. The agitator looked the same too. It washed reasonably well and spun out dryer than the more expensive models. That was the other thing about these washers. After the GM Frigidaire washer that spun clothing much drier than most washers, the White Westinghouse models left the clothes with much more water in them, which took longer to dry. Pitiful machines.....
Greg!
Roger and I saw one of those that you described years ago at St. Vinny's here, and I was instructed to go wash my hands after I touched it. Just looking at the thing--a single-knobbed, BOL Wards-badged wonder--caused my soul to wilt. I'd rather go beat laundry on a rock. At least with a BOL GE, you had a respectable washer, albeit without the fun of the Filter-Flo, or any options.
I still have the deluxe control panel on the shelf from the programmed version of these machines. I loved mine, but if a required repair extends beyond replacing a belt, they go in the trash. And no, they are not a 1-18, by any stretch of an LSD-enhanced imagination. 1-12 is more like it.
I laughed about the dryers being utter crap--in that respect, they carried the GM-Frigidaire legacy forward nicely. 1-18s had the privilege of being one of the few washers to outlast their dryers handily.
I was lamenting to Scott when he visited last that we needed a super-capacity gas dryer, since the little '78 Kenmore is ill-equipped to deal with the monster loads that the 1-18 (a real one) can crank out. He said, "What you need is a 1-18 matching dryer!" at which point I clutched my pearls in horror. David cleared his throat, and noted that what we need is a clothesline. ;-)
I believe my Maytag 1993 Dependable Care dryer is only like 6.2 or 6.3 cu. ft.  It can handle 13 or 14 sets of towels that come out of the 4.5 cu. ft. Duet.  Or a huge load of whites.  But anything that's of a "clothes" nature, the washer load gets divided in 2 dryer loads for wrinkle purposes.
BIG DRYERS
I once had an older model Montgomery Wards dryer that would definitely hold the load of clothes that the 1-18 GM Frigidaire could wash. It was noisy and bits of lint and such blew about the room, but it dried them pretty well and was a huge dryer. Of course the lint build up with those was bad too. Gas ones would catch on fire sometimes from the lint.
Monster Dryer
How about a Samsung 9.5 cu ft?? Another thread.
I've never had a WCI dryer, I never bothered to pick one up.
With the addition of the KM Elite 27" dryer, I have three WP built dryers that handle the bulk of the machine-drying. I continue to be madly in love with my '66 Whirlpool Mark XII dryer, currently installed in the garage. 37,000 BTUs of drying power, it never fails to turn out a perfectly dry load. Even big loads from the current washer-of-the-week in the garage, the 18lb Lady Executive Hotpoint, everything comes out dry without fail.
Hmmm
"5.9 CF 29" KM dryer will easily dry any load that one can cram into a 1-18 washer"
John, our's doesn't. But I wonder, then, if it's a 5.9 CF model. This is the smaller-door, not bumped-out back model. Gas with auto-dry (time/temperature only, no moisture-sensing here). If we use Auto Dry, and dump a full load from the 1-18 in there, it'll take two runnings to produce a uniformly (usually by then, over-dry) load; the clothes on the outside may be dry on the first cycle, but there will be a core of semi-moist clothing within.
Running loads only filled to the Normal level on the 1-18 resolves this, as does--of course--giving everything two passes through the dryer (or subdividing a Maxi-sized load), but if run through twice, then items are so over-dry in some instances that you could generate electricity for a small African village from the polyester-based items.
The fact that extending the time, or reducing the load, or removing dry items as they happen from the drum all seem to remedy the issue suggests to me that the capacity just isn't quite enough.
We haven't noticed any aberrant behavior, and the solenoids fire just fine--the dryer is outside, so it has no vent to work against at all. It's clean as a whistle, airflow is strong and smooth, the seals are good, and it has fresh rollers, belt, idler pulley, and Nylon glide from about six months ago.
Is it true, then, that there's a slightly larger-capacity model--and might that not be a better choice for us in this case?
9.5 cu ft
Perfect for the quest to do laundry once a month, and be done in one load. :-) I love that Lady Executive, Greg! I want to see pictures of you with it set up under some fab piece of Mediterranean-style furniture and a swag lamp, with you in a sundress and your hair up, smiling coyly at the camera. ;-)
We actually kicked around the idea of getting a modern dryer, but I loathe electronics (they screw me everytime), so I don't want to go there.
I also thought about the Norge negative-pressure dryers. Ralph and I tore one apart and rehabbed it when I had my Wards set in Oakland, and it was a good (albeit noisy) dryer performance-wise (with an end-of-cycle signal that would get you written up by the HOA, and send you stomping back to the laundry room from the other end of the house, yelling "All right, all RIGHT, ALL RIIIIGHT!!")
The Norge system seems a little pissy about airflow--as in, lint buildup is forever a risk, and easily clogs the chute at the front of the drum. I hadn't thought about the older positive-pressure dryers--can you even get parts for them if you needed them?
I'm a little loathe to get a gas Wards/Norge positive-pressure, Sock Jet dryer, anyway--even though ours lives outside on--and under--concrete. Roger and I found one years ago that was so full of lint that the burner had started to singe the accumulation around the door, and surely it was a few cycles away from a major house fire.
fire
You right about it. That was why my parents old '57 Norge dryer went when it did. It caught fire and luckily was self contained. They replaced it with the "Premier" gas dryer that matched the '63 GE washer they already had replaced the Norge one with.
Frankendryer
My KA dryer with the sort of oval drum opening in the two piece Kenmore front, the electronic dryness control for Normal and Peppermint Press, the 70 minute timed dry cycle and the 37K BTU modulating flame burner holds a lot and dries it FAST. It brings a load from any of the washers up to 165F exhaust temperature at the end of the vent tube in 5 to 8 minutes and holds it there until the machine goes into cooldown, which means that even though it is very fast, the air and fabric temperatures are held to the safe & optimal peppermint press dewrinkling temperature whether wet or dry. Unfortunately, it is probably dangerous to operate in the basement so it has to stay outside where it is used during air conditioning season.
There are so many things to dislike about WCI washers, but certainly the salt in the wound for the AW family is that we lost GM Frigidaires to these cheap, ill-conceived machines.
However...thirty-five years' distance from that horrendous seismic shock allows a soft spot in my heart for these red-headed stepchildren.  Logic and facts not included, LOL.
Chris Matthews brought up something last week when discussing the proposed Pacific Trade deal. He talked about how trade with Japan improved our auto manufacturing. He said that it used to be that cars did not last very long, which was a general overstatement, but largely true, but that now Toyotas run for decades which, again, was an overstatement, but largely true. I remember that with every new car daddy bought, he had to make a list to present to the dealer after the first week of things that had to be corrected. Our auto manufacturing spasm was largely brought on by the 2 oil crises in the 70s and the inability or refusal of the American auto manufacturers to offer high mileage cars. When the air pollution controls went on cars in the late 60s, gas mileage really suffered as if the Big Three were saying, don't tell us how to make cars. So, in the absence of domestic cars that got good mileage, the Japanese cars became the standard for quality. As has been said here previously, the GM auto lines subsidized the Frigidaire Appliance line and corporate intransigence led to the loss of profit which led to the sale. It was a very sad time in America for many reasons.
Glad some people have a soft spot. I don't, and it has nothing to do with the GM to WCI sale. It is entirely about having suffered with 2 different early 90s Frigidaires a total of 3 different periods of time. (Yes, one of those monsters came into my life two different times, and, yes, the second time I half thought I'd died, and thought I'd gone to hell.) I am guessing the total time was about 4 years. The four longest years of my life--even surviving the last term of George Bush seemed to go faster and be a more pleasant experience.
Not unreasonable, although it can be argued that a museum might show a good picture of both good and bad of the past... And by that thinking, what better choice to show washers at their worst than a WCI Frigidaire?
Samuel,
The burner in it is from an OLD Kenmore dryer with a perforated tub back which was a much less efficient dryer and therefore ran at higher temperatures. My KA is, of course, a modern dryer with the solid bulkhead at the back of the drum so much more of the heat actually flows through the drying fabrics instead of flowing behind the drum like in the old dryers. Also, there is not the space for pulleys between the back of the drum and the back of the dryer cabinet like in the older dryers so more heat is closer to the back of the cabinet. Because of this and the fact that newer dryers operate at much lower temperatures and have burners that are only rated for maybe 22K BTUs, the dryer, especially the back, gets much warmer during operation than it was designed for. In normal operation, the load would not reach 165F in the peppermint press cycle until the fabrics were dry or almost dry instead of during the whole cycle. Given that the cement block wall was framed out and that the dryer is extra deep because of the large capacity, I would have to put fireproof sheetrock on the wall and then the dryer would have to sit way forward of the washer to allow for the vent so it is not worth it. This way, the gas dryers outside the basement door under the deck get used during the air conditioning months, usually starting in April and going through part of October. Then they get a rest and the indoor electric dryers get used during the heating season. I have the perfect matching electric dryer and they both
match the KA top loader that dates from the late 80s with the black and chrome control panel.
John (LordKenmore)-- I had two of those washers, as well. The first was a 1987 or '88 Frigidaire. WCI had already been acquired by Electrolux at that point, but a few features remained from the GM 1-18 days; the circle-spray fill and spin-drain for example. The tub indexed, but not so wildly as would later versions. Washing sheets wasn't a problem. The machine behaved quite like an early 1970s Westinghouse.
Then came the 2005 Frigidaire top-loader. Tub indexing increased to a startling 180 to 270 degrees depending on the load size. This ridiculous amount of indexing, though fun to watch, was problematic in two ways: It seriously reduced the effectiveness of its new dual-action agitator due to the very short clockwise power stroke and it tangled large items like sheets and tablecloths unmercifully---as I'm sure you remember. It wasn't unusual to open the lid at the end of a cycle to find sheets in one huge, tangled ball, occasionally lock-wrapped around the agitator. In fact, the machine's only strong point was its ability to spin these extremely unbalanced loads at full speed without walking.
So, to be more precise about it, the logic-be-damned soft spot I have for WCI Frigidaires is limited to the early-to-mid 1980s.
Wow! That means that Frigidaire sort of reverted back to the days of the early pulsator agitator that used to tie your clothes in knots! The knots were practically dry when it finished though.
Wow. I never tried to figure out how much the ones I used indexed, but it was nothing like that!
I never had huge problems with tangled sheets. I think they did tangle, but I don't recall any huge nightmares. Instead, the sheet problem I had seemed to be a problem where part of the sheet would just sit above the water, sort of like an iceberg. Trips to visit the washer to make sure sheets were getting washed or rinsed properly were very much a fact of life.
And I never really felt that the cleaning ability was very good. It worked OK for me, since I seldom get anything very dirty. Most laundry here is about freshening. But even there there may have been issues; I noticed differences between laundry detergents more than I have in any other washer I've used. I feel sorry for those who owned one of these, and who had really messy laundry (spouse of mechanic, parent of active three year old, etc).
Another thought, too...
Unlike some here, I have generally had only one washing machine at my disposal. My tolerance of the Frigidaires might have been a lot better if there had been a better machine available. ("Hmmm...load 1 has some tough stains. Those go to the Kenmore. Load 2--sheets, yes, Kenmore. Load 3, towels to freshen. Well, I can do that now in the Frigidaire, and entertain myself watching the tub index!")
At one point, I did toy with the idea of purposely having one of those Frigidaires as a second machine. At that time, I was the lucky user of an old Kenmore BD. That washer was fabulous. The only practical problem was the capacity was limited. It was enough for day to day laundry. Indeed, it was ideally sized for me and my needs day to day. But...every now and then, one needs to wash bigger loads. It occurred to me that Frigidaire tubs seemed bigger. It wouldn't work as well, but for blankets and the like, I don't need super powerful cleaning action.
"MAN!" ("Woman" and "Children", too!
One Frigidaire Washer ad in our P.O.D.'s, after another!!!!
Primitive-, Refined-GM, or WCI?  Don't know which to go with!!!!
That is, these "One Speed, Tiny Tub" Sh-Boom ("Sh-boom, sh-boom"...) Boxes of the '50's, the "not ready for Prime Time" of the '60's, that at least have the features, including the tearin' up everything you put in 'er!, something from the '70's w/ the Capacity, but "Not All Models Available In All Colors" and the "disagreeable dashboards" that have the more they do, the less room given for the print that rubs off w/ age, or the 1980's "we're jus' gonna make these like ANY OTHER DAMN WASHIN' MACHINE w/ a CONVENTIONAL BLADE, but somehow the way they used to be, only with LOT'S'A PLASTIK!!!! junk...!!!!
-- Dave
