9.5 cu ft
Perfect for the quest to do laundry once a month, and be done in one load.
I love that Lady Executive, Greg! I want to see pictures of you with it set up under some fab piece of Mediterranean-style furniture and a swag lamp, with you in a sundress and your hair up, smiling coyly at the camera. ;-)
We actually kicked around the idea of getting a modern dryer, but I loathe electronics (they screw me everytime), so I don't want to go there.
I also thought about the Norge negative-pressure dryers. Ralph and I tore one apart and rehabbed it when I had my Wards set in Oakland, and it was a good (albeit noisy) dryer performance-wise (with an end-of-cycle signal that would get you written up by the HOA, and send you stomping back to the laundry room from the other end of the house, yelling "All right, all RIGHT, ALL RIIIIGHT!!")
The Norge system seems a little pissy about airflow--as in, lint buildup is forever a risk, and easily clogs the chute at the front of the drum. I hadn't thought about the older positive-pressure dryers--can you even get parts for them if you needed them?
I'm a little loathe to get a gas Wards/Norge positive-pressure, Sock Jet dryer, anyway--even though ours lives outside on--and under--concrete. Roger and I found one years ago that was so full of lint that the burner had started to singe the accumulation around the door, and surely it was a few cycles away from a major house fire.
