Not my video but got me wonder what causes the tub to hit the sides of the machine. I noticed this keeps happening on newer machines.
but from a purely engineering standpoint, low vibration at high spin speeds is the goal.
I did not watch the video past 2min that is correct.
But the motor does cut out at that point.
That almost looks like some weird resonance happening there - but it also does collide in the early ramp up phase.
And the TC5 spins at 710.
The TRs do spin at 820 - but they have a variable speed motor, with an inverter - and thus most likely OOB sensing & control.
BTW don't EVER do what they are doing towards the end there.
Don't ever try to stop the tub from moving with your hand.
You do NOT have the strength in your hand to stop 40lbs or so moving at that speed.
All that's gonna happen is your hand being crushed or your skin being ripped by any sharp point.
Speed Queens are made of actual metal, not tinfoil. Also, no matter what the design particulars, there will always be a period of time during spin-up or down when the speed has to pass through a resonant phase that may be outside the suspension's ability to control. A bang or so is probably normal for some washers, constant ruckus is a bigger issue...@henene4:
The tub banging gets worse toward the end of the video as the machine's spin speed increases.
You're not wrong in a typical sense, but there is something else going on with this machine in the video.
Speed Queen spins at 810 rpm and vibrates less than a hinging suspension machine.
