fltcoils
My daily driver, a harvest gold maytag A606 washer from 72-74 era (no perm press on dial, just soak) needs service. When filling the water pours out of the cast alum boss where the transmission attaches to the tub. And the transmission is not happy either, won't agitate well. That explains the puddle of black water on the floor (black?).
Of course this is a great place to find reference material.
Kenny if you are around the home of champions and automatic timers this weekend, might you have time to offer moral support? I figure I can either fix this A606 or reassemble my 1-18 to get going again. The mechanicals of the 1-18 are done, just need to lube the bellows and shaft oring seal and do it.
I've had this A606 washer apart before to replace the tub seal (1987), and another time apart to rebuild the transmission (1999), replaced motor (2008). Funny thing in all this, I got this dependable maytag from my mom in 1987, she is still using the "new" 1987 direct drive whirlpool from then, the whirlpool hasn't had a single problem yet.
Anyhow, I think I need to at a minimum replace the tub seal and flush/refill the transmission (with what?). I'm afraid if I wait the water in the transmission will cause corrosion damage.
1)??pour hot water on agitator to get it loose? Just pulling on it didn't work, and any hot water will quickly be running past my feet so....I can try while tip toeing about in the hot puddle. Any other recommendations for this step 1?
2) I think the transmission is flooded as well, I even see the cork from the lower pulley coming loose....
on the brighter side, the front, lid and tub cover/band came off easily enough, and the lint filter was clean (ha ha).
That's it for now, gotta goto the landraumat to get whites de-soaped.
