UK Wash In - Hoover Matchboxes - with a twist!
Tommy Hoover
Thanks Simon for pulling that one out, great to see, maybe some LSD will help to make it all clearer :-)
Great vid Paul............sounds like my 3243........and distributes the same...........and thinking so does the AS1.....i love them
Thanks
Gary
Before i let this thread fall into the archives....
I just wanted to post some piccies of the machine, the day after we collected it.
Thanks to Mike for driving...seen here, drinking a well earned brew from our 'Liberator' mugs (note the colours!)....
showing the unusual, yet simple, cold fill method for this machine.
Basically feed the cold fill pipe down through the length of the steam vent!
Door Rubbers
Paul this is a brilliant set up (not that i am biased of course)..........
In one of the fots, the door rubber appears to be the later type of door rubber that has the white plastic band clamp around it
As far as I know these are not totally suitable on proud door,round door machines, if i am talking out of my ars. then ignore me
But my AS1 has one of these fitted and i have noticed that it doesnt always seal properly, and i think you mentioned a dribble from this machine, in which case just replace it with the older fitting type and the problem should be sorted
Yours
Teknical ted
Cornwall
Noted Gary
Will double check when we next get the machine plumbed in.
I only remember a dribble, when the door was opened once the cycle finished. Door seemed tight against the seal, when the machine contained water.
Will heed the warning though and investigate, when she is brought out to play next time.
Cheers
Paul
p.s how is the AS1?
dribbles
Hello Paul
Maybe it is ok then, only i bought a round door/proud door rubber and these dont use a band clamp and are the same profile as the keymatic one
AS1 is supporting the ice box as present, going to order bearings and another (spare) door rubber........but im holding off for a while as i need to get a soap front (ice box handle is the same size)...........just a thought!
Gary
Hi ..
What a lovely pair you have there.
How I love a stacked pair.
I would love to see a stacked pair of Hot-Libs ( purple) again.
Classic .
Kindest regards.
Louis.
Hi Louis...
'I would love to see a stacked pair of Hot-Libs ( purple) again'
Wouldnt we all!
Maybe one day.
Paul
Highlines
Go for it Rob..............I have seen a couple of similar type cookers at work over the years, kitchen units everything........ if only i had the room and the house to do it, i know some one who has a complete "English Rose" kitchen for sale
Yes i can see "ange" asking "Bev" if it "cooks chickens and things" :-)
HI Paul..
Please forgive me if someone has mentioned or asked this before but, has anyone worked or seen the "props" department at the BBC ?
Do they have many vintage machines "in stock" for 1950-70's period productions ?
I imagine a warehouse somewhere, packed with vintage appliances.... Perhaps I'm wrong ?
Kindest regards.
Louis.
