launderess
Your machine has a whiff about it
Because you are killing it with soap...
Pure soap for constant use in front loaders will harm most machines. Leaving aside the issue of scum deposits pure soaps contain fats and oils that can and probably will eat away at the rubber and other components inside the machine. Worse because you cannot scrub away these various deposits the moist and warm conditions inside your washer from a wonderful breeding ground for mold and mildew.
Think of your bathtub and how it looks after a week or (God forbid) longer if not cleaned to remove soap scum. It is that scum and residue that promotes the mildew and mold you see on grout.
Can understand if financial circumstances are tight, just hunt around for good "HE" detergents on sale and stock up. You will be spending more, much more if you must replace your washing machine every few years because of damage caused by soap.
To sum up soap is fine for the occasional wash in a H-axis washer. However if you truly want to go that route then best get shot of it and look for a top loading washer or even a twin-tub or wringer.
