Ralph,
Like I said earlier, these vacuum motors are surprisingly strong and torquey when they are working right.
Is there any way you can bypass the switch when the motor is installed under the dash? That would eliminate the switch as a source of vacuum loss. Or have you already tried that?
On my little truck saga... fixed the u-joints... that part is fine... but now a new potentially major problem has cropped up... the truck overheated the other night (I had it in second gear on the freeway, inadvertantly). Yesterday, after refilling the radiator, it blew out a core plug shortly after I got on the freeway. Finally had to get a tow back home when the temp gauge pegged high. Spent most of the day today replacing the core plug (had to pull the exhaust headers/pipes, which had frozen bolts yada yada yada, took a long time to free them up). Plus had to pull the starter. Installed the new core plug (I just happened to have a whole bag of them), and just got home after hunting down new exhaust manifold-header bolts etc. I'm ready to put it all back together tomorrow but in the back of my mind I'm fearing that either the radiator is plugged (don't think so, it flows pretty well) or there is an exhaust to cooling system head gasket leak that is causing excessive cooling system temperatures and pressures. I haven't seen any water in the oil or oil in the coolant, so that much is good, but there might be a serious problem underlying the overheating.
Anyway, another weekend shot ;-)...
