Stephanie:
You'll be very happy with these if they become yours. They're later 806's, with every feature Maytag offered at the time. They are very flexible machines. I have a pair of these in Almond as daily drivers, in addition to the early 806's I'm working on as time permits.
It's bliss to have the wide range of options these washers offer - one of my loads might be an extra-large load of whites, needing a soak, normal agitation, a high hot-water level, and a warm rinse. The next might be a small load of brights, needing a low cold-water level, a cold rinse, and gentle agitation. The washer does both - and lots more - beautifully.
The dryer is also great. If you get these, the dryer has a lighted drum, and often, the light is burned out and the light's lens is broken or missing. This needs to be corrected; you can still get the lens. If it's not present, lint goes into the interior of the dryer, which creates a fire hazard pretty quickly. The light lens is located inside the door opening on the front bulkhead, at about the 10 o'clock position. You will either feel the lens (good) or a hole (project time).
I hope these are yours soon!
