Washers, dryers, and dishwashers at Golden Haven Apartments
gelaundry4ever
Nov 18, 2014
4,174
Temple, Texas, USA
Hey guys, I found out that Golden Haven has Whirlpool Commercial washers and dryers, model# CAE2745fq and CEM2745fq. The dishwashers are Frigidaire model#ffbd1831uw. What could you tell me about these? The washers and dryers cost $1.00 per load with coins both wash and dry. Does the washer have a straight vane or dual action agitator? What about the dispensers? I'd be willing to bring Downy balls if necessary. How good are the dryers? As for the dishwashers, what are the cycles and options? Do they have a detergent and rinse aid dispenser, or just a detergent dispenser minus the rinse aid? I should be moving soon. I hope they perform well. Thank you.
If that dishwasher is similar to a cheapie 2019 FD I given and junked a couple years ago , there is a brushed PMDC wash motor and a PM wet rotor drain pump.The dishwasher i was given had bad door switch-something these are very prone to.Dishwasher was grubby,so junked it.
Did it have both detergent and rinse aid dispensers? How did the arms operate? Did they run at once or separately? I'm curious to know about the washer and dryer which are listed above.
These are VMW commercial units. Seem more reliable than the residential ones but the shocks often fail on these eventually.
Not as good as the commercial Speed Queens that last 15+ years.
Aren't they the same as their Maytag counterparts? What makes them different if they're not the same from Whirlpool and their Maytag commercial counterparts?
Did the arms alternate, or did they run all at once?
