Ways to Save Money on Laundry....
It could be worse. They do at least allow the use of hot water for loads like underwear and towels. I have seen some frugality experts who wash EVERYTHING in cold. And wash everything TOGETHER.
This has not happened to me as far as I know, but this thought makes me cringe: having dinner at one of these frugality nut's houses, where the kitchen towels used to dry the hand washed dishes and the fancy napkins on the table were both washed in tap cold water with the host's underwear, and then line dried in a dank basement.
Well, I can see using this plan if you're REALLY SUPER cheap. Altogether you save what, $200 a year. That's $16.66 a month. Give or take a few dollars. If I wanna save money I want it to be at least 3 or 4 times that amount a month.
I do a lot of those things....
and many work on saving money....although, I am proud to say that I don't wash my kitchen towels in cold water with my underwear and hang them in a dank basement...LOL.
I'm all for the line drying and have even made my own washing powder before, but I do like hot water for certain sanitary things, along with sorting my clothes properly. The white vinegar they mentioned, although not a softener, does make a lovely rinsing agent for those detergent sensitive individuals (like me).
line drying
I do that that all the time, hardly ever use the dryer! but OUTSIDE where the sun and air are, I think it saves more than what they say it dose. OTOH I hardly ever use cold water! just cant convince myself that anything gets clean in cold. Have dryer sheets but never use them, unless I have ants ! they work pretty well to make them go away? ( Makes me wonder?) Hot or warm water, warm rinse, lined dried! Now that class LOL
Well, there are good points on what the author says! But others... let's forget them :)
1- Reduce the amount of detergent you use in each load and save money.
(this couldn't be more true! And the clothes will be better rinsed! I do this all the time, I always use soft water doses even if I have hard water and my clothes are sparkling clean all the time, 280 ml of powder for 5 kg of laundry is just too much! But this is how P&G works!)
2- Reserve hot water for towels, washcloths, bed linens and clothing close to the body, such as undergarments.
(I can only partly agree to this, washing clothes in COLD water in the long run is going to make them smell, expecially if your cold water is under 15°C/59°F, so I wash everything that needs "cold" at 40°C and hot is 60°C or extended at 40°C if stuff is not too dirty.)
PS: the dial on the photo looks like a Candy!
3- "That's going to be your biggest money saver," she says. "Use the free sun and the free air to dry your clothes."
(Couldn't agree more! Clothes spun at just 800 rpm dry indoors overnight, even thick stuff like jeans, plus that adds valuable moisture to the underfloor heating that leaves the house very dry. In the summer I dry on the balcony.) That saves 1 euro per load!
4- Fabric softener isn't necessary to get clothing soft and wearable
(This is just my opinion but I always use the full dose of fabric softener, otherwise, clothes are stiff and not because they're not well rinsed in my case, adding half a cup of of baking soda to EACH rinse or a cup of vinegar to the final rinse?!?!? That is going to cost double than using fabric softener! )
5- Make your own laundry detergent
GROSS! No other words needed, at least over here you can find a perfectly working enzyme, oxi-bleach, optical brightening detergent at less than 10 cents per load, that is going to cost less than homemade detergent too and will work better even if it is a value brand.
6- Buy an Energy Star-certified washer
Well, if I were unemployed I'd rather use my current machine to death before buying a new one...
7- Buy easy-to-clean clothes
Again, if I were unemployed I don't think I'd go shopping everyday...
And easy to clean clothes? Just get 100% cotton stuff!
Why would they recommend adding baking soda to the rinse? That is just putting an alkaline salt into the fabrics that is going to make them feel harsh when dried. Vinegar makes more sense if you add it before the final rinse. Drying the clothes with the residue of the reaction of vinegar with the alkalinity of the detergent is not good for the fabrics. This is corporate brain washing that "baking soda" is pure. It's like when Arm & Hammer came out with that crappy no phosphate laundry detergent in the late 60s or early 70s and made people think that baking soda was a principal ingredient in the formula when it was actually mostly cheap, harsh washing soda. When you examined washer tubs of people who used detergents with washing soda and baking soda, you could feel the fine grit left behind when the tub dried. That fine grit or dust was in the clothes, too. I doubt if enough baking soda was left behind to neutralize perspiration odors when the garments were worn.
Tom:
How would you rate A&H detergent of today? Do you think there's any comparison to the formula now than when it first debuted (I do use it every so often)?
Vern:
As I've stated in previous posts, I'm also a laundromat user. I do laundry every 2 1/2 to 3 weeks. Depending on if I do some extra loads ( pillow, blankets, comforter, bath and kitchen mats, etc.), my expense for washing is generally in the 8-10 dollar range (1.25 per washer for either Maytag top loader or Neptune, 1.75 for triple load Ipso, and 1.75 for drying).
Although I'd LOVE to have my own washer and dryer (hopefully one of these days), the trip to the laundromat usually takes around (tops) 2 hours. HOWEVER, after my last trip and seeing an illiterate BIOTCH change her baby's diaper on the folding table (the NERVE of some people!), I'll be taking a few Clorox Wipes with me and do a wipe down before I proceed in folding my clean laundry.
I used to think that most people use all different temperatures to wash their clothes. Hot for whites & towels, warm for clothing and cold for woolens. But after observing people and asking I can't believe the number of people who wash everything they have in Cold/Cold.
I had Karen ask some of her friends who do this why do they do it. The answers ranged from it's cheaper to "cold water doesn't damage zippers". (????)
Ultimate solution: paper clothing...
Better yet! Let's just go NAKED all summer! Think of the savings..... Hmmmm this could be fun!
Arm and Hammer Powdered Detergent of today-
Is, I think, pretty good. I have used it as recently as a year ago, and was pleased by its performance. However, for me, for the time being, it is Sears Ultra Plus in the orange box.
As to cold water washing.....I only wash things labeled "cold water only" in cold.
Everything else is in warm or hot! Cold rinse, usually, though. Since it's just me, it does not make a huge difference in my energy bills (I pay for water, gas, and electricity. My landlord pays trash removal, but I pay for recycling.)
Lawrence/Maytagbear
Lawrence:
I agree with you. I think the cost difference may be just a couple of bucks per month using different wash temps vs just using cold all the time.
Doing laundry is not that hard! Just sort according to fabric type and colorfastness, use warmer temps for sanitary items and cooler temps for delicates or things that may shrink. Remove promptly from washer or dryer. That's it.
How can so many people screw this simple formula up?
Wash full loads. An underloaded machine will not get the clothes as clean.
Measure detergent carefully, especially the new X2 liquids. Using the cap to measure does not work as well as a small measuring cup, many caps are too big around to get an accurate reading.
Ken D.
Keep in Mind...
....that it's just me and my furbabies here, but I did one of those online energy audits where you plug in how you use your appliances and all that stuff. I was looking to buy a new washing machine at the time and wanted to see if going Energy Star would be a good option for me. Here is what I found.
By changing my habits, and going with all new Energy Star appliances, I would be able to save a whopping $19 a YEAR....$11 a year if I bought an energy star washer alone. I decided to go with an old design top loader for cheap instead....and do more line drying. That saves several dollars a month....more than what a lot of these sites promote as green and frugal.
I don't know nothing about Arm & Hammer detergent. Sorry.
I realize that because of my parents' careers, I am way too concerned about germs. Friday morning, on the way into work I watched a man who had been holding one of the bars as he stood in the Metro car, release the bar and then use that same hand to rub his face: mouth, nose and eye areas and I honestly wondered how anyone with an ounce of knowledge can do that. My father predictd the rise in bacteria resistant to ways we have controlled them. He predicted and saw the rise of infections when they pulled hexachlorophene out of the hand soaps used in hospitals because it was found to permeate the skin of babies. In that case, don't bathe babies in it, but let people caring for babies and others in the hospital use it to wash up between caring for one patient and moving on to the next. The thought of doctors sitting on the edge of beds in their street clothes as a way of showing their caring relationship and warm bedside manner SCREAMS to me of spreading filth from all manner of public surfaces onto the bed linens of an already sick person. Doctors' ties are among the most efficient germ spreaders known. Laundering in cold water not only does not kill germs, it leaves organic matter such as oily dirt on which the microbes can feed. Yech.
"By changing my habits, and going with all new Energy Star appliances, I would be able to save a whopping $19 a YEAR....$11 a year if I bought an energy star washer alone."
I've often wondered what the real world savings are...or aren't. Not that there aren't probably cases where people would see a huge savings by going with an Energy Star machine. (Expensive electricity plus many loads using hot water a week will do it.) But I'm guessing there are a lot of people who won't see a significant energy saving. The worst case are those who use tap cold for every load, and then buy a front load machine. I'm sure at least some people like this get sold on the idea of saving energy, even though they never use anything but cold.
