What can you tell me about a 1999 Whirlpool Gold?
4 way Hydro Sweep might fit; check your bushings for wear
We have a 2000 model year KitchenAid (KUDM25) that looks very similar to this inside. The big differences are that the KA has the 4 way Hydro sweep bottom spray arm and has a stainless tub but the top spray arm setup looks the same and the pump looks very similar. The wing bolt holding the bottom spray arm on looks identical.
It has been a great dishwasher and with the KitchenAid quiet package it isn't loud at all.
One thing I would do is check the nylon bushings that the spray arms ride on. The ones for the lower (Hydro sweep) arm wore out causing the spray arm to ride up, not spin, etc. Your bushings may be the same ones. The result was awful washing performance. A new set for the top (not bad but changed while I was at it) and bottom and it is running like new again.
Andrew S.
silverware basket
I have a Quiet Partner II. The dishwasher in the picture has a bracket missing on the right side. With both brackets in the front, you can put the silverware basket hookes up to the front of the bottom rack. And someone mentioned it will fit on the left side of the bottom rack. Keep that dishwasher!!! In three years I have had that thing replaced twice and now the dispensers don't work(jet dry & detergant). The repair people say they will be out in two months, that was three months ago. I live past the end of the earth, so I have to wait till there are a bunch of calls before someone will come out. Then wait for the parts and go again
You've got a gem!
All these new dishwasher maybe nice and fancy, but that dishwasher will remove dried on spinach/oatmeal pots on the top rack.
These new machines cannot get the whole pot clean and this should be the standard test for all dishwasher.
Stop looking at the plates and focus on the pots CR.!
Oh, jeez... I'm glad y'all like it, it just goes to show that water conditions vary from place to place and not everything that works/fails in one home will do the same in another.
For the record: I've *left* one behind (rental apartment, landlord was a friend and when the old dishwasher in the apartment broke I got one of those -- only difference it was black) and I do not regret leaving it behind one bit. I never liked that machine, it was better than doing dishes by hand but that was it.
To begin with, it etched all our dishes on the first month. Apparently, to save water/energy, it had only one rinse or, to be more precise, the model I had would go thru all the pre-washes/washes, then do *one* "purge" and then one rinse on the Normal cycle. That was it. Then straight to dry. So, if we used enough dishwasher detergent to clean the load, it wasn't rinsed enough and it would etch the dishes. If we used less detergent, it didn't clean at all. We were told that our water was "too soft" and we should use less detergent, even though the water was naturally soft (4 grains/gallon or less) and using less detergent wasn't getting the dishes clean.
So, after replacing glasses and other dishes a couple of times, we took to using (the proper cycle sequences escape me right now) either the Heavy or Pots-n-Pans cycle(s) to force two rinses. Of course, doing so used more water right off the bat and took the machine from "energy star" to a regular non-energy star machine, which is not what we were promised. On the other hand, it improved the cleaning for the silverware.
Oh, yes, the silverware baskets on the door thing. What a pain. If you didn't load it just so, the silverware would not get clean. Just try to convince lazy-ass/distracted room mates to load the plates next to the silverware and pay attention to how they loaded the silverware in it (instead of their usual just drop handfuls of silverware in each compartment). Good luck with that. Of course, performance would improve if you clipped the silverware basket to the front of the lower rack -- until said distracted room mates would come and handle the racks with all of the gentleness of a gorilla, so the basket would fall off the rack and send silverware all over the machine. And putting the basket inside the rack would of course take up lots of space, which is precisely the opposite of the selling point ("silverware on the door gives you more space in the racks"). Before I had that machine I often wondered if the designers of household appliances ever even *use* them, some have some weird design problems that one would have expected would surface on the very first few times they'd *use* the things. But no, in fact I've met plenty of people (including in-laws) that had similar appliances and just loved them, particularly the silverware basket in the door thing. Of course, all of those people live in areas with hard water and do not own a water softener, so that might explain why it worked so well for them.
You could say that, at least back then, the DoE did not have the kind of people that could test machines for performance and/or energy use, I hope they improved. Among the clueless things the "Energy Star" people did were running the dishwashers without dirty dishes in (they loaded the machines with clean dishes), which gave some machine with sensors an abnormal leg up all the others, and also they did not test machines in very hard, hard, medium and soft water (neither does Consumers Report, BTW, if I recall correctly they only test the machines in hard water, never in soft/softened water), so machines that fail to rinse well never got penalized for it. I wouldn't hold my breath though, rumor has it that in the last year or so the "energy star" people awarded energy star status to a few french-door bottom freezer fridges, but did not run them with the water/ice dispenser on -- when people started calling the DoE about it, they simply removed the energy star status but did not even apologize for it nor, as far as I can tell, change their tests to account for stuff like that.
I wonder what it would take to get folks like us to work for the testing places like DoE and Consumer Reports. My impression is that they are bored to tears with their jobs and want to get it over with instead of seeing it as a way to help improve the state of the art and defend the consumers.
earthling177......
It seems as though you were the victim of a buildup of tolerances. You had naturally soft water which sucks for washing. You had a house full of roommates that were too stupid to load a dishwasher. You obviously used the incorrect detergent for your needs.
Naturally soft water means you do have to use less detergent. If you use too much, it will cause etching. It says it right on the box, not to mention it's been well documented since the 1960s. Powdered detergent is usually always worse about etching than a liquid or gel.....did you ever try other brands or types? Etching can also be caused by water that isn't hot enough. That's why the installation manual clearly states that the water is supposed to be 140˚F at the faucet for proper washability.
I agree that the location of the silverware rack sucks, but I'm just as lazy as your roommates, and I've never pulled a dirty piece of silverware out of the machine.
Our water here is relatively hard, so for proper washing, I pretty well have to put a little extra soap in the bottom of the machine for it to get the soap concentration high enough. We're one of those places that has the white crust that forms on the faucet aerators. I've had the same glassware since 2002, and even with the awful GE/Hotpoint junker I had at my old apartment, I've never had a problem with etching. The detergent matters more than the machine or the water.
In fact, I have a repair manual that was written in the early 1970s that has about a 3 page dissertation about water hardness and the importance of choosing the proper soap. It clearly states that if the customer is having problems with etching on glassware, to try another brand of detergent.
It sounds to me like you are taking out aggression on a machine that was abused and used improperly. Not because it's a bad machine. Out of all the machines I've used (and I've used a lot), this one hands-down does the best job.
Well, let's try again then, you can ask people who know me. I've tried all the dishwasher detergents available at supermarkets at the time. I *know* about soft-water, amount of detergents etc... I even mentioned that we reduced the amount of detergents just to find out it did not clean enough, and when we used a (normal) amount that would clean it did not rinse well enough and, when we used more aggressive cycles that rinsed better, the problem disappeared (usually, if you use more detergent and a heavier, longer hotter cycle with soft water the etching is supposed to get worse). Obviously, in the normal cycle the machine did not rinse well enough -- why?, because for the majority of people that have normal to hard water, it will rinse just fine then. The correct attitude would be for the designers to realize that if they wanted the energy star so badly, they'd have to redesign the wash system and make do with a little less water in the wash part so they could guarantee two rinses every time. But neither DoE or Consumers Union *test* for rinsing, so what they hey, it's out the door. Also, while I do not remove the blame from my room mates, I will say I lived with that particular crowd for a number of years with different dishwashers and that was the only model that gave us that much grief, which does stand out -- other machines, even when giving mediocre results, were better than the one under discussion.
To be honest, as I mentioned before, I'm glad people like the machine (and I think I was even fair enough to mention that some people I know that had similar/identical models with hard water in my group of friends/family liked their machines, that's why I got one). I put in my experience not to rain on anyone's parade, or to be aggressive. I figured I'd just mention what I had experienced because (a) clearly the design did not account for, at least in the model/year I got it (it may have changed, they seem to have several different user guides with different cycles on the web site) for people with soft water who might want to use something other than Heavy or Pots-n-Pans; and (b) other people may have or know people who have that machine and had/have the same problems we experienced and be wondering "WTF?, why is it we have a completely different outcome?" and one of the answers is "water quality/hardness". My voice is supposed to add to all of your experiences and become our experiences, not subtract, detract or invalidate what people are saying here. Also, it serves to alert you to the fact that if you move your exact same machine to a place with soft/softened water, don't think the machine is broken, it may be just behaving as designed.
But I still hope that the people who design and/or test household appliances start doing a better job. When people think along the lines of "what's the worst possible situation?" and test just for that one thing, failing to realize/test for some other similar worst case scenario (in this case the actual other end of the spectrum, soft/softened water is a bad case that needs to be accounted for too!), we consumers lose big time. And, over time, the manufacturers lose too -- guess if I bought from that same manufacturer when I moved? Also, guess if my friends and/or relatives who also had soft water and had similar problems with designs like that bought what I bought or went back to the design we're discussing here?
I don't wish any manufacturer any ill -- quite the contrary, we *all* win when manufacturers improve. And you can bet I'm way more careful now when I'm out buying dishwashers, any mention of "purge" makes me double my attention and wonder if that's a cycle I intent to use. Notice also, that purges per se are not terrible, there are machines that use them quite effectively, I had friends with KitchenAid dishwashers that used the technique and rinsed quite well.
Cheers,
-- Paulo.
My 2001 Kenmore Ultra Wash had identical racks and wash arms to this Whirlpool and it was the best dishwasher that I've ever owned! My sister has it now and it is still in use. To avoid the purge and get a full 2 rinses, we always used the Hi Temp Wash button. For the Pots/Pans, Normal, and Water Miser cycles the sequence was W/W/R/R with varying times for each cycle. Never a dirty pot or dish came out of this machine.
One man's trash...
Isn't it funny how two people can have the same machines and yet have such different results from them?
I can see why Earthling would despise his machine and agree 100% with the piss poor design of the silverware rack in the door, and look at the included pics here and note the additional one on the top of the door as well. Every Whirlpool machine I have had thru my garage here or used at one time or another(short time, thankfully) did a poor job on the silverware.
Want a quick and easy solution, install a rack from a Kenmore which has the detergent dispenser in the same place. It has an elongated rack to fit in the recess that the silverware basket took up and gives you space to put the silverware rack in thye dishrack.
It is ridiculous to have to actually "rack" your silver to get it clean. Yes, no nesting allowed but still, how much water really gets to hit that stuff in that location? And block it with a bowl and you will have to wash the silverware by hand!
Now on to those who have gone out and bought the Tall Tub machines and can't get clean dishes out of one of them!!
In all honesty, what can you expect to get from a machine that has a 1/5 hp pump as opposed to one with a 1/3 or 1/2 hp pump?
The tall tubs have small pumps and redesigned water channels to deliver the water to the dishes.
Take a look at the underside of your Hydrosweep on a tall tub vs. one on a pre tall tub model! The water passageways are miniscule and the water outlets are small too. If you cannot deliver the water volume in a given time frame, then you have to extend the time frame for the cycle to do its work. Way around it is the soil sensor technology. If the water seems clean, then the dishes must be too.But thankfully it does also monitor temps so the new detergents can do their job better.
The power module delivered gallons more volume than these new small pumps and will probably outlast them 2-3 to 1. How many people here have had to replace their tall tub pumps before 5 years? I have taken in 3 machines like that already and 2 of them had pumps diagnosed by Sears as needing replacement. All of them were built in 2004.
Now here's the catch for those with tall tubs that don't clean:
If you assume the machine is a garbage disposer because the salesperson and literature tells you about the soft food disposer blade that the machine has, think again and look at the picture of it on the door!
Does it look as big and powerful as the disposer in your sink?
I don't think so and neither will you. It is a SOFT food disposer. Pasta, bread, veggies, some meats.. not bones and such.
The point is this, these tall tubs all have smaller pumps with much smaller pump intakes and smaller channels to funnel that water into the pump.
If you have not been kind to them, I will strongly suggest that you take the top of the pump housing off and look inside the sump where the water goes into the pump, right in front of that "hard working" pretend knife blade and see what has accumulated there. In one of those machines I mentioned,I took out 12 lollipop sticks, 20 orange or grapefruit pits, 3 screws, 2 washers, saran wrap and paper and about a half dozen toothpicks. Did I mention a few pieces of broken glass?
The diagnosis on this machine was that it needed a new pump and motor. Sure it didn't pump any water and made noise.. no water could get to the intake because the crap blocked it all and the noises were from the screws getting thrown around by the blade.
I sold the person who had this machine a GU950 Whirpool with the powermodule and he and his wife said they love it and that they cannot remember when their dishes came out so clean!
I currently use that very same Kenmore they condemned as my overflow machine in the garage and the pump is just fine and the machine DOES do a great job on anything I throw in it. Yes it takes a long time to do the dishes but No big deal.
So if your tall tub cleans poorly, get in there and clean it out or have one of us come by to do it!
If you have a machine with picky racking requirements, see if you can change the racks and get better results. I have sold Kenmore racks to Whirlpool users and they are all much happier now.
Boy did I ramble or what?
I have the kenmore version at my mothers, a little different, Ultra Wash series, the silverware rack goes on the left hand side, but so is my dispenser there too...mine shoots water up thu the middle to the second shower arm and then to the roof...what a great machine, had it since 1988, never a single problem with it,,,,have seen these models taken apart, so freakin easy, 4 twisting clips underneath, unscrew the drain nozzle, pull the wiring plug off, open the door and grab the wash arm and pull up and out, the complete ultra wash module,in seconds...reverse to install the new one, I was amazed!
