lid switch bypass
There's an easier way to bypass the lid switch...behind the console, on the right side (facing washer), you can feel around and find the lever that controls the switch (it is flat brass, if you can see behind). Wedge a piece of something (I used a rubber spatula blade over the flat piece) and the switch is permanently bypassed, or at least until you change it. You might have to "experiment" to find just the right place for blocking...but it will work. If anyone has a problem finding that, private message me with your phone number, and I'll walk you through the process.
