Back on topic
Following is a pretty decent review along with comments on the WP heat pump dryers:
http://www.greenbuildingadvisor.com/blogs/dept/guest-blogs/heat-pump-clothes-dryers
Cannot find mention of it in owner's manual, but apparently it does seem that the WP dryers do allow for faster drying using a some sort of different method than heat pump. Another review stated on "quick" the dryer did a full load in about 45 minutes. That kind of speed simply cannot come from a pure condenser/heat pump drying system alone, especially one that handles large loads as the WP units. This tells one that there is some sort of resistance heating elements that can be used to crank up the heat where necessary. That would explain the 30amp requirements.
Furthermore WP like most others hailing heat pump technology makes much noise about heated or cooled air not being vented out of the home. Well there are great periods of the year when neither the heating nor air conditioning systems are running for most of the USA. Today for instance here in NYC the boilers didn't come on and we certainly didn't run the AC, this was with outdoor temps in the low 60's (F).
http://www.trustedreviews.com/whirlpool-hscx10431-review#disqus_thread
