Hello all. I can't get this washer to drain, and I'm just about to put a bullet into the front to expedite the process. I'll take one last shot (pun intended).
It would fill/agitate, but then seemed to pause when it should have been pumping out the water. I would advance the timer by hand and it would agitate again, but stop once more when it came time to drain.
I removed the timer and found a connection that had obviously been running too hot (upper right in photo). Could something jam the pump? This afternoon I'll try tipping it over to see if I can find anything obvious.
